I have a '76 550F that I purchased from the original owner. Here's a thread where I got the bike back on the road:
http://forums.sohc4.net/index.php?topic=126113.msg1434228#msg1434228 For as long as I've owned the bike it's ran rich. Here's a thread that covered that:
http://forums.sohc4.net/index.php?topic=139399.msg1577133#msg1577133 Recently, I've felt some performance issues. At first, I thought it was because I've been riding my ZRX1100 so much and the 550F is literally HALF the displacement.
I sold my other 550's so I didn't have another to compare it to. But after riding a 350F and 400F I have at my disposal, it's clear that something isn't right.
Now that Winter is on it's way I've decided to dig in and give it a good going over and try to get to the bottom of it. I will be doing the full 3,000 mile tune-up, to include:
*oil and filter
*valve adjustment
*cam chain adjustment
*timing check, including advancer operation
*new NGK D7EA plugs
*check coils for resistance, etc. I installed new plug caps when I got the bike.
The bike is stock, other than a Pamco ignition and a UNI foam filter in the stock air box.
I will also pull the carbs for yet another cleaning and inspection. I occasionally get some fuel from an overflow tube(s) when initially starting the bike. This only seems to happen after I let the bike sit for an extended period, but I will be installing new float valves just to be SURE that it's not having an effect on the float operation/fuel level.
I also ordered new main jet O-rings and, if needed, some aftermarket 98 main jets (I can't find Keihin mains at the moment).
I pulled the emulsion tubes and needles a while back, but I will pull at least one to verify the clip position and part #'s. I
really don't think they're worn, as this bike has less than 7K original miles on it.
I will set the float height at 22 mm and verify that the new float valves work at that height by using the clear tube method.
Carbs will be bench synced and then vacuum synced once on the bike.
While the tank is off and the plugs are out, I will do a compression test.
I'm waiting on parts to show up right now, but I will report back once I dig in. Can anyone else offer ANY suggestions as to what to check or do while I'm in here?
I noticed yesterday that, if I look in the spark plug holes, I can see a fair amount of carbon on the piston tops. Would it be OK to use a little bit of SeaFoam down the spark plug holes and let the piston tops soak for a bit?
