I bought a '83 CB1000C once that a PO had a 'friend' adjust the valves. Well, he didn't know what he was doing and both #1 exhaust valves were shimmed WAY too thick and they didn't close. Though he was lucky enough NOT to burn the valves, LOTS of carbon built up, the valves wouldn't close and compression went south. He sold it to me thinking the #1 cylinder was toast. The advice from the guys at the DOHC club was to properly shim the valves, put a HEAVY dose of Seafoam in the fuel and then 'Run-it-like-you-stole-it!', and it worked! The carbon cleared out and compression came back to near normal so I'm a BIG fan of Seafoam!
