Author Topic: I want to clear over a pr. of oem decals on a PC'd tank  (Read 874 times)
Offline grcamna2
« on: November 28, 2014, 07:20:08 PM »
Do any of you dudes have experience on applying something like Duplicolor clear lacquer over PC and then trying to buff it to match ? or close match ? The PC is standard gloss black but not PC clear.
75' CB400F/'bunch o' parts'
Offline faux fiddy
  • bike in a box
Re: I want to clear over a pr. of oem decals on a PC'd tank
« Reply #1 on: November 28, 2014, 09:11:59 PM »
Different stuff does different things together. In my experience touching up an old paint job things are less likely to react.
Fresh paint does different things, a new coat/two tone on something that hasn't cured for a long time can react, curdle or shrink the paint underneath. Even paints that are made to use together can react if both coats are fresh.
The fancy blue 3m striping tape especially made for the purpose if bodywork and  can wreak havoc by pulling off a coat after you paint your line. I don't recommend it on uncured paint at all.
Lacquer on Lacquer  with a rattle can be easy, I've touched up furniture and guitars with a rattle can.  Best to be as dust free as possible, low humidity. You can build it up into the old laquer on a chip by just pointing the can and one quick spray. Smooth it out with thousand grit paper and finer depending the finish you want, repeat as necessary.
It might work, but I would test an area or other part if I could, and as far as decals, I think laquer was always the way they were done in the day, right?  You may not want to do the whole tank and obviously keep the gas off them.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline grcamna2
« Reply #2 on: November 28, 2014, 09:55:51 PM »
yeah,
I'm thinking the clear lacquer has a lot more shine to it than the standard gloss black PC that was oven baked at 400+ degrees and it's real hard.I'm not sure if I can try to sand the PC a little w/ 1000-1500 grit wetdry  paper(the tank was never meant for any show quality finish but just a daily driver w/ dents,etc. under the PC)and then apply the clear lacquer to the sides only to 'clear in' the 2 Honda wings that I'd like to apply.I'm wanting to clear them over to keep'em in good shape in case of fuel spills,etc. I'm just not sure if Powder Coating(PC)will even let me apply the decals and then clear over them because I never tried that.I only did it on similar paint like lacquer to lacquer & enamel to enamel compatible paints.
« Reply #3 on: November 28, 2014, 10:36:14 PM »
Ask forum member Powderman....?
Offline grcamna2
« Reply #4 on: December 04, 2014, 04:38:36 PM »
bump
« Reply #5 on: December 04, 2014, 10:24:54 PM »
Offline grcamna2
« Reply #6 on: December 05, 2014, 06:19:32 AM »
I plan on it... but still hoping he or someone else might respond
