Author Topic: 76 F model project- mono shock suspension(aka-Kingsnake)  (Read 124814 times)
Offline POPS 911
Re: 76 F model project- mono shock suspension
« Reply #750 on: December 27, 2018, 05:37:56 am »
FRANK: You and wife have a great holiday ..... a Fire Chief I work for on the big RED truck gave me this answer Richie  [POPS] don't give me a problem but give me YOUR solution and with 30 years on the Fire Dept. that is what I DID = that Chief is still alive and I thank him every month at our retires lunch for those words of wisdom. Your solution will be put in your tool box and can be taken out when needed.
POPS BK911
Offline dragracer
  • CB750F Dragbike
« Reply #751 on: December 27, 2018, 10:36:03 pm »
Pops, all I can do at this point is concentrate on the solution. I'll pull the engine off tomorrow night, split the cases and reinstall the shaft and gear. We'll be ready for the 2019 season.
Happy New Year to you. Hope to see you at a race next season.
POPS BK911
Offline dragracer
  • CB750F Dragbike
« Reply #752 on: December 28, 2018, 07:47:40 pm »
Pull the engine off tonight. I'll split the cases tomorrow, clean everything up and reinstall the kick shaft and gear. Hope to get it done, reinstalled and started up by Sunday evening.
Sometimes we have to go backwards to move forward. I'm still focused on the goal.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #753 on: December 28, 2018, 08:58:28 pm »
Looks like all you lack is finishing Frankie! What are you waiting for? Get busy!
Offline dragracer
  • CB750F Dragbike
« Reply #754 on: December 28, 2018, 09:53:20 pm »
I got hungry so I knew it was time to quit. I ran out of shop snacks.  :P. I'll stock up tomorrow so I can fuel up and keep working. Now if I can just hang this thing back on the chassis without nicking the powder coating. Ahhh, screw it, its a dragbike, not a show bike. Lol.
Offline dragracer
  • CB750F Dragbike
« Reply #755 on: December 29, 2018, 06:07:23 pm »
I had to take a few step backwards but I'm moving ahead now.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #756 on: December 31, 2018, 02:30:26 am »
Nothing like oil pressure to an engine builder, lol, K. ;D
BentON Racing Website
BentON Racing Facebook
Offline dragracer
  • CB750F Dragbike
« Reply #757 on: January 04, 2019, 09:16:11 am »
Quick update, I got the engine back on the frame and after pre-lubing it again, I was able to establish oil pressure. Spinning it over with just the starter for a short while netted 55 psi. I buttoned everything up and put fire in the hole. It cranked up right away and idled but I did have to do some adjustments minor idle screw adjustments on the Lectrons. I didn't hear any knocking, rattling or crazy noises. I shut it down because I knew at least one of the carbs was too rich so I pulled the plugs and one was smutty, another much to lean and the others on the boarder line. I also noticed an oil leak on the rotor button but only a minimal amount inside the ignition cavity. Its possibly a crank seal leak or the o-ring is bad on the advancer stud causing the oil to push out under pressure thereby running along the stud to the button. I'll check that out tonight to diagnose the problem. The seal us new but it could be the problem. Worse case scenario, the engine gets pulled again to inspect the seal.
Offline dragracer
  • CB750F Dragbike
« Reply #758 on: February 02, 2019, 07:19:02 pm »
A short video of the bike running after I found and corrected a few electrical problems. The smoke you see is due to the carbs being too rich. Slowly trying to tweak the Lectrons to get the right plug color. Those carbs typically run rich anyway. No slow speed or main jets, only a metering rod for adjustment of the mixture. Designed for idle and full throttle only.
« Last Edit: February 02, 2019, 11:05:42 pm by dragracer »
Offline dragracer
  • CB750F Dragbike
« Reply #759 on: February 02, 2019, 08:38:01 pm »
Offline gschuld
« Reply #760 on: February 03, 2019, 04:24:41 am »
Nice Frankie....😎
Offline dragracer
  • CB750F Dragbike
« Reply #761 on: August 20, 2019, 11:02:16 pm »
About to get started back on this project again. I set it aside for a moment mainly because racing season had begun in full force and i've been chasing points in 3 different series. Hoping to debut this bike at the Cup race in Darlington next month.
Offline dragracer
  • CB750F Dragbike
« Reply #762 on: August 20, 2019, 11:07:54 pm »
Forgot to post these progress pictures.  It's just aesthetic but something is still happening now to get the bike ready. Shiny paint never won a race but at least we can try to look good going down the drag strip. Lol
Offline gschuld
« Reply #763 on: August 21, 2019, 09:10:21 am »
Looking good, hope it’s up and running soon.
George
« Reply #764 on: August 21, 2019, 09:19:11 am »
Nice. Did you spray?
Offline dragracer
  • CB750F Dragbike
« Reply #765 on: August 21, 2019, 10:32:26 am »
I didn't paint this one Jerry. My brother helped out and got a fella in Atlanta to lay the color.  It's close to what's on my other bike.
Offline POPS 911
« Reply #766 on: August 23, 2019, 09:25:16 am »
Frank : I will call you soon = don't forget the two KZ1000 motors sitting in my garage and the J-MODEL S/G BIKE ON THE LIFT is yours to complete and to compete , you are the MAN.
POPS BK911
« Reply #767 on: August 23, 2019, 11:27:28 am »
Frank, shiny paint has less aero drag than matt paint or dirty paint. Looks good!
David
Offline dragracer
  • CB750F Dragbike
« Reply #768 on: August 23, 2019, 12:20:31 pm »
POPS BK911
Thanks Richard,
Sounds like its time for the wife and I to take a road trip to Ohio. Or maybe you can ask JT or Crow to throw them in their vehicle and bring them to the next race we'll attend together. I can use anything Kaw related.
  • Gusto mo titi ko?
    • project
« Reply #769 on: August 23, 2019, 03:25:12 pm »
Looking good!
Offline dragracer
  • CB750F Dragbike
« Reply #770 on: September 03, 2019, 09:42:58 am »
My brother picked up the body work from the painter and brought it to me this weekend.  I must say it turned out very well.  Now I just need to put the top end back together and get it to the dragstrip for testing.  We plan to debut it at the Darlington Dragway, Man Cup race at the end of the month.
« Reply #771 on: September 03, 2019, 09:54:31 am »
That is some really nice lipstick!
Really looks great. Good luck finishing it up.
David
« Reply #772 on: September 03, 2019, 10:30:01 am »
DAMN Frank!! Really nice. Now you gotta get Old Faithful freshened up  :)
Offline dragracer
  • CB750F Dragbike
« Reply #773 on: September 03, 2019, 10:54:23 am »
A few more.
Offline dragracer
  • CB750F Dragbike
« Reply #774 on: September 03, 2019, 11:04:09 am »
Well,  even if we aren't fast, we want to look good. Lol. But pretty never won a race and that's our goal.  I want  to make this bike as consistent and reliable as my F2. I've got no complaints with it in 20 plus years.
