Author Topic: HELP!!!!Guestion honda cb 500-550 four transmission.  (Read 380 times)
Offline kranta
  • honda cb 250RS 1981 CAFE & honda cb 500 four 1978.
« on: December 02, 2014, 01:42:36 AM »
So, is here some one who can post me picture or video where shows how much both shafts gears touch to each others.?? And can someones post pictures or videos or even tell how they put transmission in upper crank case. And is this possible that you put main shaft in upper crank case and then you put counter shaft in so that you take counter shaft on your hands and put it so that both shafts gears are meshing to each others so that you keep it in air so
 that gears are meshing to each others like in picture. (but i mean to do this with other shaft)  and then you roll it down on its place so that counter shafts gears are rolling with main shafts gears. NOT shaft only its gears. IS THIS POSSIBLE? and please answer on THIS GUESTION! IS THIS POSSIBLE!?
sorry about bad english.
« Last Edit: December 02, 2014, 10:55:53 PM by kranta »
