Author Topic: Seeley CB750 Honda Registry  (Read 73270 times)
Offline Zunspec
Re: Seeley CB750 Honda Registry
« Reply #150 on: March 08, 2017, 03:51:23 AM »
Hi scottly,
Here are photos of my front tank mount:
As you can see fairly conventional rubber bungs which slide into recesses on the tank.
Cheers  Geoff
« Reply #151 on: March 08, 2017, 08:40:57 PM »
My frame has no provisions for mounting the rubbers, and my tank doesn't have the recesses they would slide into. Maybe after Colin started assembling complete bikes he changed some things? ;)
I started working on the rod for the rear tie-down, but I have very little clearance for one under the rear of the tank, so I'm pursuing my original plan to fabricate alloy "hooks" from thin strips, that curve under the frame tubes, with a piece of the bungee attached. The hooks will be between the outside edge of the seat pan and the frame, and will be positively anchored by the front seat mounting screws. I'll post pics when I have something to show, if anyone's interested.
Offline Zunspec
« Reply #152 on: March 09, 2017, 03:56:17 AM »
Hello scottly,
I was just looking at some google photos of Seeley bare frames.  There appears to be a small dia. tube fixed to the frame on the top tube just behind the headstock. From this I assume a threaded stud pushes through which in turn screw's into the tank rubbers.  I could not find a detail photo the tank showing the welded on recesses though but I assume they must have been std.  I'll do some disassembling and take some photo's if it is of any help.  Sounds as if you have a way ahead for your situation though.
I suspect that many frames might have been altered by their original builders to suit their preferred fixing method, only guessing there though.
Cheers  Geoff
Offline Tim2005
« Reply #153 on: March 09, 2017, 11:54:20 AM »
On mine, it's just a tube fixed across the frame, no threads, the rubbers (which are standard 750 but cut down a bit narrower) just push over it. The tank doesn't have actual recesses, just curved pieces of alloy welded in the appropriate place, kind of like tiny fenders
« Reply #154 on: March 09, 2017, 07:18:12 PM »
How about the rear of your tank, Tim? Does your bike also have the rod mounted across the top of the battery tray, with the rubber loop? At this point, I'm just curious...
Offline 01Thomas
« Reply #155 on: March 10, 2017, 03:13:57 PM »
I keep the rubbers in place with a very long cable tie (zip tie) through that little tube, over the rubbers and connecting under that little tube.
1971 Honda CB750 Four K1 [Engine: CB750E-1113521 / Frame: CB750-1113838]
1977 Seeley Honda CB750F (F1) [Engine: CB750E-2551214 / Frame No: SH7-655F]
'96 Yamaha YZF750SP & '81 Moto Guzzi SP1000 & '80 Moto Guzzi 850 LeMans II & '82 Bimota KB-3 [Frame No 49] & '66 Ducati 50 SL/1 & '53 Miele K-50 & '38 Miele 98
Offline 01Thomas
« Reply #156 on: March 10, 2017, 03:23:58 PM »
There is no dedicated fuel tank mounting point for the rear of the fuel tank. I made two bung-holders which I attached to the front seat mounting tubes with short screws from the 'inside' of the frame, if you know what I mean. That front seat mounting threaded tube then still has plenty of thread to hold the seat mounting screws which screw in from the outside of the frame.
For the rubber bung I used a piece of shock-cord. This is very strong and stretchy rubber cord used by the sailing/yachting crowd to keep ropes in their place.
« Reply #157 on: March 10, 2017, 06:53:18 PM »
No tube nor fenders on my bike..
« Reply #158 on: March 10, 2017, 07:04:27 PM »
My new rear hold down strap. I also have been making some new cushions between the underside of the tank and the frame, to replace the foam pipe insulation and chunks of inner tube that I fitted last go-a-round. ::) The cushion at the front is OK, but the ones at the rear need some revising.
Offline Zunspec
« Reply #159 on: March 11, 2017, 02:08:29 AM »
Hi scottly,
A neat solution for your rear tank strap.  Your tank seems to be a bit different wrt it's mounting requirements and also the frame with that front mount tube not being there.  I wonder if your frame might have been a special order for racing.  Have you ever contacted Colin to see what his records say ?
Cheers  Geoff
Offline slikwilli420
  • Master of Disaster
« Reply #160 on: March 19, 2017, 05:23:21 PM »
Here are the photos of the seat Axl had made for me. I chose not to use this "original replica" but to use the copy made from this one. More photos to follow
Are these seats something that is still made? Always loves the Seeley bodywork but no one makes it.
Offline 01Thomas
« Reply #161 on: April 05, 2017, 01:56:20 PM »
I'm not aware of nyone making Seeley bodywork commercially.
I'm not near my bike or my spare seat and I won't be for another couple of months but it should not be too difficult for someone to pull a mould and make a replica.
« Reply #162 on: April 06, 2017, 10:20:20 PM »
Hi scottly,
Cheers  Geoff
Hey Geoff, I'm wondering now if the front tank mounts were added later to satisfy the German requirements? Perhaps they wanted something more positive than a rubber band to secure the tank. ;) Does anyone know exactly what mods were required to meet the German spec?
Scott
Offline Zunspec
« Reply #163 on: April 07, 2017, 04:34:30 AM »
Hi scottly,
My chassis is a German spec. one (SH7-GER-672F).  I have assumed that the front tank mounts which slip over the Honda mount rubbers were Seeley std.  Saying that the genuine Seeley tank I have on my T500 race bike only uses a rubber to hold down the front of the tank so maybe UK spec. Seeley 750s are the same.
One of the differences between the UK and German spec. chassis had something to do with the steering lock I believe.  Whether that was for more or less lock I have no idea though.
Cheers  Geoff
« Reply #164 on: April 07, 2017, 07:35:48 PM »
Great pic Scottly- will use it on the new Register site, thanks.
Any progress on the new site, Tim?
My winter project was to re-fit the electric starter, and since the seat and fuel tank had to be removed to fit a larger battery, I decided a cosmetic make-over was due. ;)
Offline 01Thomas
« Reply #165 on: April 30, 2017, 11:42:29 AM »
Looking Good Scottly!
« Reply #166 on: April 30, 2017, 11:10:17 PM »
Thanks Thomas. Since there was a dent in the top front of the tank, I decided to paint only the front part, inspired somewhat by the BSA 441 Victor. I thought it would also make the tank look less massive? In any case I'm happy with it for the time being, as the weather is improving and it's time for riding instead of wrenching. ;D
Offline 01Thomas
« Reply #167 on: May 01, 2017, 06:26:50 AM »
My tank also has a slight dent in the top surface...
Offline eli
  • Life is hard if you cannot work on your bike...
    • Seeley-Honda
« Reply #169 on: May 02, 2018, 12:33:48 AM »
Hey there,
as Scottly suggested, I post what is the known history of my Seeley frame #SH-7 GER 573:
Nothing.
The frame was offered without papers by a salvage guy in 2002 on Ebay. He even sold the swing arm in a separate auction and I had lots of trouble to find the buyer of that. In the end, frame and swing arm were mine. That's it  :( :(
As my bike was one of the first in Axls registry (met him personally before he died) and as I hold the website seeley-honda.com I was hoping that a former owner would get in contact, but that didn't happen till today.
eli
Will my patience hold till the thing is finished???
Seeley build:
http://forums.sohc4.net/index.php/topic,171911.0.html
« Reply #170 on: May 02, 2018, 08:20:10 PM »
I found that website many years ago, when I first accessed the internet; it told me more about my bike than the previous/original owner. ;D I had thought it was Axl's site? The memorial board on this forum was created following his passing.
http://forums.sohc4.net/index.php/topic,50400.0.html
Offline eli
    • Seeley-Honda
« Reply #171 on: May 03, 2018, 12:01:26 AM »
Yeah. Axl was a cool guy.
No, the site is mine, I made it even earlier than Axl started his register(as you can easily see by the fossil-like looks)
Thank you for finding the information valuable  ;D
One day, I will update everything and fill it up with all the stuff i aquired in the meantime...
Seeley build:
Offline jruff5585
« Reply #172 on: June 23, 2018, 02:07:24 PM »
Well hello, I purchased Jags Seeley and it just got here last Sunday. I don't have time to do anything with it right now but I have 99% of the parts to build it. So as soon as I get started I'll let you know
Offline jruff5585
« Reply #173 on: June 23, 2018, 02:46:35 PM »
BTW I'm building the bike as an endurance racer. Here's the fairing I'm using that I was asking about mounts for, I don't think it was ever mounted.
Offline eli
    • Seeley-Honda
« Reply #174 on: June 25, 2018, 08:26:12 AM »
Hi, this is what my mount looks like.
Something like that plus some fix at the sides should be easy to make...
eli
Seeley build:
