Author Topic: 1980 CB750 master cylinder question  (Read 1677 times)
WHALEMAN
« on: October 05, 2006, 03:46:19 PM »
Hi, I am a single cam guy but am going through a friends 80 CB750C. The master Cylinder is leaking under the clear part of the reservoir. The parts finch shows an o-ring on the clear part sealing it to the metal base. I can not pull the clear part off. It will spin around easy but even light prying will not remove it. Double cam experts please help. Dan
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
Re: 1980 CB750 master cylinder question
« Reply #1 on: October 05, 2006, 04:27:07 PM »
                    Well, I've got an 80' CB750K but, by the time I got it, it had a master cylinder off an older
             SOHC model. So, I'm sorry to say that I can't be much help to you.   LOL though.
                                                        Later on, Bill
Member # 1969
Offline crazypj
  • I'm brill, me
« Reply #2 on: October 06, 2006, 06:42:50 AM »
There is probably corrosion abouve the 'o' ring. you will have to pry/twist/pry/lever/force/pry to get it apart. If its rotating you have all the screws out and its only the'o'ring holding things together.  I dont know of any easy way to get it apart. I think K&L Supply company list a new resevoir if you break it as it was fited to just about every Honda from 1979~81. I just looked it up, page 291 2006 catalogue part # 32-8043 fits CM 400 through to gold Wing. It isnt the angled type fited to CB650 but would work( maybe the alloy bzse was angled?, I forget)
PJ
WHALEMAN
« Reply #3 on: October 06, 2006, 09:54:46 AM »
Thanks Crazy, You were correct. The good news is I was able to get it off without breaking it.
