Author Topic: WTF was I thinking?  (Read 8444 times)
Offline natron602
Re: WTF was I thinking?
« Reply #25 on: December 09, 2014, 05:51:18 PM »
Was starting to wonder about the tank. Any tips on tools I'll discover I don't have or things I'll likely not know being a novice and this being my first time inside an engine?
Offline natron602
« Reply #26 on: December 09, 2014, 06:00:51 PM »
Specifically in the realm of the reinstall.
Offline calj737
  • I refuse...
« Reply #27 on: December 09, 2014, 06:14:26 PM »
If you open the engine, I can't stress enough your need for the following (in no particular order):
Manual
Camera
Beer
Torque wrench
PB Blaster
Patience
Some extra hair to pull out later
A good, stable internet connection
More beer
And a healthy dose of realism.
There's no magic or mystery to these things, but they are assembled in just such a way on purpose. Take your time, take lots of pictures for future reference, and expect to do things more than once, or twice, sometimes three times if it's your first time opening one of these up.
All those little o-rings, pucks, and washers are important. The steel ball bearings too, don't lose these little nasties all over the garage floor. Suggest a clean piece of carpet under the engine as you disassemble to help catch those critters that try and run when you loosen them up from 40 years of bondage and neglect.
Everything will take longer and cost more than you are planning. It's not a race, just go slow, step-by-step and it will turn out pretty well for you.
I'll raise the first frosty to your journey!
« Last Edit: December 09, 2014, 07:38:23 PM by calj737 »
Offline Restoration Fan
  • My wife will never call me
« Reply #28 on: December 09, 2014, 06:43:48 PM »
Manual
Camera
Beer
Torque wrench
PB Blaster
Patience
Some extra to pull out later
More beer
Great advice as usual.  But I would also add the following recommended tools:
Air compressor
Bench grinder/polisher
You may be able to do it without them but it sure does make it easier with them.
Online Don R
« Reply #29 on: December 09, 2014, 09:14:59 PM »
 Is that #5 tag riveted to the tank?
Offline natron602
« Reply #30 on: December 09, 2014, 10:35:14 PM »
Just held with wax in that pic and covering a dent/hole. Was thinking about mounting it there somehow while I figure the rest out.
Offline flatlander
« Reply #31 on: December 09, 2014, 11:09:09 PM »
looks not quite as nice as my '76 550K tank
Yep, looks like a 74-76 550K tank.
must be a US thing. in europe they had these style tanks on the 500 but not on the 550. always baffles me how/why honda came up with these small regional differences.
Offline natron602
« Reply #32 on: December 10, 2014, 05:04:40 AM »
Manual
Camera
Beer
Torque wrench
PB Blaster
Patience
More beer
Have all those things. It's already apart I've just got to get my hands on a valve spring compressor so I can get it back together.  Can anyone tell me how many hours I can expect to spend getting it back in?
Offline calj737
  • I refuse...
« Reply #33 on: December 10, 2014, 05:10:19 AM »
There's a few threads on here about a DIY compressor for the valves. Motorcycle types are different, and require much deeper offset to reach the springs.
"How many hours to get it back in?" Do you mean to reassemble the engine and reinstall into the frame? Expect at least a weekend to reassemble if it's you're first time AND you have all the parts on hand.
Popping the motor into the frame, 90 minutes. Reconnecting everything, another weekend day. Can be done faster, may well take you longer. Too subjective wihtout details. I'd plan on a month of weekends personally and that's if you don't need any machining services or contracted work by others.
« Reply #34 on: December 10, 2014, 05:12:11 AM »
Hey Flat - your 550 is an F model right? Differant tank.
Offline knottedknickers
« Reply #35 on: December 10, 2014, 06:49:49 AM »
Like:
here
here
here
Good luck!
CB750 K6 http://forums.sohc4.net/index.php?topic=141388.0
The plural of "anecdote" is not "data" (Borgmann 2002:5).
Offline flatlander
« Reply #36 on: December 10, 2014, 09:43:55 AM »
yes right. but i think of the k models only the k3 was sold in europe which had a tank like the F, with the little hatch. might be wrong but that's the impression i get after poking around the web a bit.
Offline natron602
« Reply #37 on: December 10, 2014, 11:04:07 AM »
Thanks guys. Once I get these puppies in I should be al lready to put it back in.
Offline natron602
« Reply #38 on: December 10, 2014, 08:28:55 PM »
Keep trying to post some before during and after pics but it's not working so I may have to spread the pics here to give an idea of where I'm at.
Offline natron602
« Reply #39 on: December 10, 2014, 08:31:32 PM »
Also managed to swap my carb syncher for a valve spring compressor for the weekend from a coworker who conveniently went to motorcycle school.
Offline natron602
« Reply #40 on: December 10, 2014, 08:33:39 PM »
Also renting a three stone honer in the morning. Any other steps to get the new (likely because I'm a dummy) rust out of and off of the cylinders?
Offline natron602
« Reply #41 on: December 10, 2014, 08:35:11 PM »
Hoping to get her together over the next two days. Peak season at The Evil Empire has me working 55-60 hour weeks and is not conducive to my motorcycle repair schedule.
Offline natron602
« Reply #42 on: December 10, 2014, 08:36:37 PM »
One more because I think I'm clever.
Offline natron602
« Reply #43 on: December 14, 2014, 11:15:07 AM »
Ran into a slight snag this weekend. Went to put the valves back in and somehow lost one valve spring washer. Bussed to the junk yard and spent a few hours going through boxes. Finally found it but still no final assembly. Got my new jacket so I'm dying to get it done.
Offline natron602
« Reply #44 on: January 06, 2015, 11:42:02 PM »
I'm bad at this.she's up and running. Spent some time using cold blue compound from Cabella's to get a little color on the tank tonight.
Offline calj737
  • I refuse...
« Reply #45 on: January 07, 2015, 03:31:54 AM »
Be aware, bluing won't tolerate moisture or oils from your hands; it will rust promptly. Use a spray clear coat and cover that thing, test the underside for compatibility before shooting the top.
Offline natron602
« Reply #46 on: January 07, 2015, 05:15:47 AM »
I live in Phoenix and plan to wipe and oil regularly. It's kind of a test run since what I really need is a new tank and at that point I'll have to pic colours. For now it's more experimentation. Thanks though. If I end up really digging it I'll either clear coat or call my buddy who builds guns for some options (maybe parkerizing?)
Offline Riceman
« Reply #47 on: January 07, 2015, 08:44:07 AM »
If you clear coat the bare metal make sure you cook the water out of the
metal with a propane torch(or something similar)or it will eventually rust
from within.
Offline natron602
« Reply #48 on: January 12, 2015, 02:47:33 PM »
Well, I've got her back on the road. Brakes and some swagger (see:cosmetic) parts are next on the agenda. She's kind of taken a turn from my original ideas. Is it a horrible idea to go forward with no real plan and just step by step put on things I like and hope it all comes together in the end?
Offline calj737
  • I refuse...
« Reply #49 on: January 12, 2015, 02:53:16 PM »
Congrats! No plan required whatsoever. Ride, enjoy, adjust, ride, adjust. Mostly, just ride and enjoy!
