Author Topic: Quick Measurement needed from a -392 head  (Read 1340 times)
Offline MidnightLamp
  • Wrenchy wrenchy wrench!
« on: December 07, 2014, 02:32:19 PM »
Trying to determine if the head I have is a stock -392 head, and was just wondering if anyone here has the exhaust port ID measurement from this head, or a picture of the port/gasket?
Cheers!
'75 CB750 - Racer
'69 CB350 - Racer
'68 Enfield 350/440(flat top) - Steet
'54 Enfield 350 - Resto
'74 Commando 850 - Restomod
'67 Enfield 750 (TT7) - Resto
Re: Quick Measurement needed from a -392 head
« Reply #1 on: December 07, 2014, 07:29:52 PM »
I got 30mm across all 4.
« Reply #2 on: December 07, 2014, 08:43:49 PM »
Sweet! Thanks Jerry! Looks like I can confirm it: all the hondamatic heads are -392 heads but with no markings. The intakes are the same size and same with the exhaust. Both the exhaust pipes and the intake rubbers are different and restrict the engine quite a bit. The cylinders are also the same, as are the rods, so if you come across one in parts...they're great for low K motor bits! The bits that are different are the crank, cam and pistons, but the rest (rods, pins, clips, towers, etc...) are all the same.
'75 CB750 - Racer
'69 CB350 - Racer
« Reply #3 on: December 07, 2014, 10:13:40 PM »
Are the chambers smooth unlike the earlier K's? No shrouding? Any numbering to the left of #3 intake on the top fin?
« Reply #4 on: December 07, 2014, 10:41:48 PM »
Chambers are smooth, no shrouding, not oblong, exactly like a -392. There is a 3 where the -392 marking usually is, and an X right before it. No other marks!
'75 CB750 - Racer
'69 CB350 - Racer
« Reply #5 on: December 08, 2014, 12:15:00 PM »
Here are a couple of pics of a K7 head. The exhaust port is approximately 32mm wide where it meets the gasket mounting surface.
« Reply #6 on: December 08, 2014, 05:32:50 PM »
Looks Identical to mine! Port measured at 30mm for me, but that might have been a mistake!
'75 CB750 - Racer
'69 CB350 - Racer
« Reply #7 on: December 08, 2014, 06:29:25 PM »
I used old school adjustable calipers to find the ID, then measured them with a dial caliper to get an accurate number. ;)
