Author Topic: Coatings on CB350K1 engine 1969  (Read 1245 times)
Offline AshimotoK0
  • CB400/4, 69 CB750K0, '69 CB250SS, CB350K1 CB500K0
« on: December 16, 2014, 12:10:36 PM »
Anyone know what the correct original finishes are on the '69 CB350K1. Looks like many parts polished alloy then clear coat (Like the cam bearing covers, top crankcase etc). Anyone know for sure?
cheers .... AshD ... UK
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.”
Re: Coatings on CB350K1 engine 1969
« Reply #1 on: December 16, 2014, 03:21:49 PM »
I have an NOS right sidecover off engine..will examine further.., may be painted... Not sure what year it is.
« Reply #2 on: December 16, 2014, 07:40:34 PM »
I have a NOS cover that is painted.
I have another that does not appear to have been painted.
 If you look up front by the oil slinger cover,  there is an oil passage bump in the case, it is on theneeds under side.  Hold cover with kicker on left, look at it from the bottom. The bulge for the oil passage, does the outer end appear rounded, or run toward back of the case, at about a 40 degree angle.
 If its angled, then I conclude that the one I have is factory painted.
« Last Edit: December 16, 2014, 07:42:17 PM by 754 »
Offline grcamna2
« Reply #3 on: December 18, 2014, 01:41:28 PM »
my 72' CB350 twin has painted cases and clutch cover.
I've been using Duplicolor engine enamel high heat paint #DE1615 'aluminum' w/ #DE1612 gray base primer engine enamel heat paint as a great match to factory engine coatings.
« Last Edit: December 18, 2014, 01:45:28 PM by grcamna2 »
Offline AshimotoK0
« Reply #4 on: September 27, 2015, 05:20:38 PM »
Found a UK supplier now for this now. Does the primer adhere OK to bare alloy?
Cheers .... Ash    UK
