Author Topic: a fluid I could use to soak old,hard elec. wires/harness cables in to soften'em  (Read 5892 times)
Offline grcamna2
I was always wondering if any of you have a 'trick' to make old hard wiring harness/electrics,wires,etc. softer ? possibly soak them in a special fluid that will do them good inside and out? I just want to be sure that the color of the insulation stays the same,but softer is certainly better... especially when removing or installing inner wire handlebar switches.
                                          Thoughts ?  ???
Offline trueblue
I wonder if Don R's 'skin so soft' method would work for that too.   ;D
http://forums.sohc4.net/index.php?topic=131810.0
1979 CB650Z
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
Sounds like time for a new harness? If it's that hard you don't want to risk any fluids getting into cracks in the insulation which might cause you problems in the future. Just a thought.
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline goofy3392
I saw a video from DCC where they soaked a harness in WD-40. They had one of the big gallon cans of it.
1976 CB550
Offline grcamna2
The wires aren't as hard as the outer cover,but just was curious if anything has been used w/ success before.
Offline mark
rocking horse piss. works every time.
F you mark...... F you.
Offline grcamna2
lol
DH
When I restored my bike ten years ago, I used WD 40 on a rag and it worked out good. I don't know if its the ideal thing to use for that purpose, but I'm still running the same harness now. Didn't harm the wire colors.
I like the Skin-so-soft idea. I'd try it on some old wiring that is otherwise junk and see how it works.
Low voltage only lol. BzzzzzAP!!!
Offline grcamna2
Could be Don's already tried that Avon sss on wiring harness,switch harness covers? I got some because of his suggestion and works good on my cycle seat cover(does smell tacky though,but that goes away)so who knows? it's worth a try  ::) what could it hurt  :)
Offline faux fiddy
  • bike in a box
If it's just for  taking it apart to clean contacts or manipulating it back into place  you might use a 100w bulb to warm them up.  Heat always helps.
I think someone said they were using peanut butter on other certain plastics.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline grcamna2
I was thinking if it was only temporary I would shoot them w/ WD and wipe'em down(I do that quite a bit on the contacts anyway to stop corrosion)and then heat the harness/outers to about 130 degrees F. before attaching it to the bike.
I just wondered if anyone's found something permanent like Wintergreen oil,etc.(although that might remove the color from the wires)to keep them soft,mainly the outer part of the harness.
peanut butter, lol  ;D Did you mean peanut oil?
DH
Yeah, I'd only wipe it down, not soak it  ;D
Offline grcamna2
bump
Offline faux fiddy
  • bike in a box
Now that I think of it I think the thread said peanut oil was what  used on an airbox to condition the plastic.
Offline 750cafe
Vinyl protectant like Armor all. Or, better yet, Mothers Back to Black bumper protectant.
Eric
Is there anything more fun than riding? They are between your legs and are quiet when you turn them off.
Offline grcamna2
I like it when the wires/insulation cover,etc. are soft again so I can take my old harnesses and 'form' them better along the bike w/o too many wire ties or cable clamps,that's the main reason I'm asking. I like to re-use old ones for vintage originality.  ;)
        thanks
Offline faux fiddy
  • bike in a box
        thanks
Sometimes it's a hard call on the sheathing, it always cracks apart near the head tube, and I think if I do a wiring harness or have to dig a wire out of a segment of harness I'm going to use the spiraled plastic conduit.
Offline grcamna2
I've used that coiled plastic cover once before John & it doesn't look to bad on a full custom build if that's what I was doing.I just like that thin flexible special 'wrap' they use back at the factory and want to preserve it if I can,that stuff is better than electrical tape and lasts longer.
Offline grcamna2
I'm basically asking if any of you members have found a fluid to soak hard plastic in(like you would w/ Wintergreen oil for old rubber)for a while so it'll soften it a bit.. ???
Offline 750cafe
Eric
Apply it many times and allow to soak in until you are happy with the results.
Eric
Offline grcamna2
ok
