Author Topic: Biggest bore in stock block with big sleeves???  (Read 6885 times)
Offline dragracer
  • CB750F Dragbike
« on: December 19, 2014, 11:01:44 pm »
Alright, looking to the old time experts on this question; What is the biggest possible bore in a stock cylinder with big sleeves??? I've seen 73mm, but how much bigger can you go in the stock block with aftermarket sleeves???
Re: Biggest bore in stock block with big sleeves???
« Reply #1 on: December 20, 2014, 12:11:41 am »
Here's a partial assortment
Measuring at the bottom of the skirt the big boy comes out at 73.59mm
Offline NalleyRacing
  • 1972 Cb750K dragbike Instagram: Drag_racer736
« Reply #2 on: December 20, 2014, 06:49:39 am »
Superbike Mike Keyte's big valve, stroker motor, used 78mm pistons in a stock SOHC block if I'm not mistaken.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #3 on: December 20, 2014, 07:08:56 am »
Yes to 78 mm. Stock block.....? Hmmmmm. ;D Bill
BentON Racing Website
BentON Racing Facebook
Offline dragracer
  • CB750F Dragbike
« Reply #4 on: December 20, 2014, 07:45:05 am »
Taking a stock block with big sleeves out to 78mm must have created some problems near the studs. Anyone on the forum go this big before???
By the way, what's the minimum allowable thickness of a sleeve after boring???
« Last Edit: December 20, 2014, 07:51:18 am by dragracer »
« Reply #5 on: December 20, 2014, 07:51:00 am »
I would  think the sleeves  would need flat spots on them, almost no support from the cylinder with sleeves showing everywhere.
    • BentON Racing
« Reply #6 on: December 20, 2014, 07:59:51 am »
Yeh, I'll go on Facebook and ask Superbike Mike, Bill ;D
Offline dragracer
  • CB750F Dragbike
« Reply #7 on: December 20, 2014, 08:20:28 am »
Thanks Bill. I'm just going through the winter crazies and running some wild thoughts around in my empty head.
« Reply #8 on: December 20, 2014, 09:24:33 am »
Same here buddy
    • BentON Racing
« Reply #9 on: December 20, 2014, 02:18:23 pm »
Lets go BIG?  ;D
Offline bear
  • Leeton in Australia
« Reply #10 on: December 20, 2014, 03:18:43 pm »
I know we run our motors for a different application to you blokes, but.
We mill the sholder of our sleeves @73mm.
Lets not forget the head is the limiting factor here if your running N/A.
Our hp curve goes flat at about 7'500 rpm, just can't get enough air into it after that.
Brian
« Reply #11 on: December 20, 2014, 03:22:20 pm »
Brian
Is that with a 33.5 intake Brian or are you up 35mm or something?
Offline dragracer
  • CB750F Dragbike
« Reply #12 on: December 20, 2014, 03:29:06 pm »
How large a bore will Mikes billet block go with nikasil.
Offline dragracer
  • CB750F Dragbike
« Reply #13 on: December 20, 2014, 03:34:49 pm »
I'm pretty sure the major concern is the limitation of the intake port, even when its maxed out. I doubt a spigot head like Kenny has will stifle a 78mm bore.
Offline bear
« Reply #14 on: December 20, 2014, 04:22:56 pm »
Brian
We're run 35mm intakes and shave .5mm or 1mm off the exhaust Mike.
I'm pretty sure your right there Frank and Johno is on the case for me on that front down here, fingers crossed.
But at the moment I have not been able to come up with a "usable" head down here that will flow much more than 80cfm and still give me enough velocity for my road racing motors.
Brian
« Last Edit: December 20, 2014, 04:46:46 pm by bear »
Offline TurboD
« Reply #15 on: December 20, 2014, 06:46:42 pm »
Yes the intake port is the limiting factor, for example if the intakes will only support 100 HP increasing CC's will not gain much if any in terms of lowering ET.
« Reply #16 on: December 21, 2014, 04:13:25 pm »
I do not recommend anything over 72mm.
« Last Edit: December 21, 2014, 04:15:03 pm by MRieck »
Offline kmb69
« Reply #17 on: December 22, 2014, 06:57:37 pm »
Little off subject, but.......
Frank,
Mike was telling me you have external oil returns on your F dragster. I guess I didn't look close enough every time I have seen your bike in person. Would you mind posting some pics?
Keith
Offline dragracer
  • CB750F Dragbike
« Reply #18 on: December 22, 2014, 08:54:33 pm »
Frank,
Keith
I'll see if i have any pictures on my lap top. If not. I'll get a few posted on here for you.
Offline dragracer
  • CB750F Dragbike
« Reply #19 on: December 22, 2014, 09:13:16 pm »
Here are a few pics of the oil drain lines. Hope it helps.
Offline dragracer
  • CB750F Dragbike
« Reply #20 on: December 22, 2014, 09:34:47 pm »
Lines in the  block.
Offline kmb69
« Reply #21 on: December 22, 2014, 09:41:56 pm »
Very nice!!! Thank you sir.
Did you do that because of the oversize studs?
Are you still draining down the studs as well?
Look like pretty big buckets - 73's?
Offline dragracer
  • CB750F Dragbike
« Reply #22 on: December 22, 2014, 10:16:53 pm »
If you look carefully at the pictures of the head, you can see that I've plugged the drain holes in the head. I used liquid metal with hi temp silicone smeared on top. It was done due to the oversize sleeves exposing the oil drain passages in the block. Dang thing leaked like a sieve til this was done.
Offline dragracer
  • CB750F Dragbike
« Reply #23 on: December 22, 2014, 11:05:13 pm »
72mm bore/1030cc. MTC pistons. RC steel rods, stock unlightened crank, F2 ported head with stock valves, titanium retainers, APE valve springs with RC327 cam.
    • BentON Racing
« Reply #24 on: December 23, 2014, 05:26:26 am »
Nice! Real nice! Can't wait for April, 2 in the 10's, 3 when undercut trans goes in Purple Rain turbo bike! K. Bill
