Author Topic: '77 Cafe Build Almost Done  (Read 5512 times)
Offline snowman
« on: December 21, 2014, 05:46:05 AM »
It's been a while since I've posted anything, so here's a pic of where I am today. My goal was to get a runner before winter set in and now I plan on finishing it off the details.
Sent from my iPad using Tapatalk
Offline snowman
Re: '77 Cafe Build Almost Done
« Reply #1 on: December 21, 2014, 08:42:35 AM »
Here's a small list of what's left to do, it includes clean up the wiring, reroute the cables, new suspension and the two unknowns are if I paint or leave it as is with no paint and a couple coats of clear.
And the last decision is whether I stay with the 4 into 1 system or go with a 4 into  2 system.
« Reply #2 on: December 21, 2014, 08:48:07 AM »
I'm a fan of the raw look, so I'd consider clear coating your body work.
Looking great.
What is your plan for rebuilding your suspension?
Offline snowman
« Reply #3 on: December 21, 2014, 09:36:17 AM »
For the suspension, I'm thinking of progressive springs in the front and Hagon shocks for the back.
You're right about putting a coat of clear on the side covers, another item to add to the list.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #4 on: December 21, 2014, 10:51:00 AM »
I'm a fan of exhausts on both sides.
I am not usually a fan of the no rear fender look, but your bike really carries it off nicely.
Offline Ford40
« Reply #5 on: December 21, 2014, 01:01:02 PM »
Did you make that seat yourself
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #6 on: December 21, 2014, 03:56:41 PM »
I like it, would be interested to know a bit about the seat too.
One comment - if you are ever tempted to squeeze a passenger on there, keep away from holes in the road. I had one very similar, with the reg. plate positioned over the rear tyre like that. Bottomed out going over a hole and the plate hit the wheel, took out the plate, light unit and fibreglass tail. Another reason to get the best rear shocks you can run to.
Build threads:
1977 CB750 F2
1958 Norton Model 99
« Reply #7 on: December 21, 2014, 04:27:17 PM »
Looks great. +1 raw tank...
Offline snowman
« Reply #8 on: December 21, 2014, 05:16:27 PM »
The tail section was made by Ian over at Twinline and his wife makes the seat pad. Super nice people to deal with.
Also I don't think I need to worry about reg. plate, because I'm not planning on taking any passengers since this will be more of a weekend warrior.
« Reply #9 on: December 21, 2014, 07:56:59 PM »
Ian has made me a couple of seats. Always outstanding quality.
Offline riverfever
« Reply #10 on: December 21, 2014, 08:27:35 PM »
Great looking bike. That seat is nice.
Offline B-EZ
« Reply #11 on: December 23, 2014, 06:04:47 PM »
Looks good! Are you still running the inner rear fender?
Offline snowman
« Reply #12 on: December 23, 2014, 08:40:19 PM »
Yes I am, wanted to the dirt off of the electronics.
« Last Edit: December 23, 2014, 08:45:17 PM by snowman »
« Reply #13 on: December 24, 2014, 09:57:30 AM »
Ah yes, now I remember the front rotor hole pattern!
Offline B-EZ
« Reply #14 on: December 24, 2014, 10:06:23 AM »
Does that seat allow you to retain the original fender mount or did you modify it? Thanks
« Last Edit: December 24, 2014, 10:07:54 AM by B-EZ »
« Reply #15 on: December 24, 2014, 11:34:06 AM »
The original cross-member is still intact, so you can attach the fender the same way.
Offline snowman
« Reply #16 on: December 24, 2014, 01:53:29 PM »
I was lucky enough that the seat fit with no significant mods. All I had to do was to heat the inner fender with a heat gun and put in a small indentation.
Offline snowman
« Reply #17 on: December 24, 2014, 01:55:57 PM »
Yes, one and the same. I was a little apprehensive that I would have reduced stopping power, but so far so good.
BTW, using the petcock that I bought from you last year.
« Reply #18 on: December 24, 2014, 03:11:10 PM »
Excellent.  I just talked to Ian today, and sent him a picture of your bike with the seat he made.
Offline snowman
« Reply #19 on: December 24, 2014, 10:14:33 PM »
Thanks and if you speak to him again, let me know what he thinks.
Offline koendd
« Reply #20 on: December 25, 2014, 01:19:35 PM »
love it!
looks real good
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
« Reply #21 on: December 25, 2014, 03:20:19 PM »
I think he always likes seeing his work come together on a bike.  The fact that you have the raw look going on is pretty cool, too.
Offline snowman
« Reply #22 on: December 28, 2014, 06:11:28 AM »
Hey guys, need some input as to where to get a chain guard for the bike. Been looking at the one sold by Carpy, I like the simplicity & clean lines but it won't fit on a '77.
Offline Riceman
« Reply #23 on: December 28, 2014, 09:06:58 AM »
Offline Chad
« Reply #24 on: December 28, 2014, 06:42:53 PM »
Agreed with the posts above. Definitely keep the raw look. One thing you might want to look into (you may already know this)... clear won't stick to raw metal. I did quite a bit of research on it because I was wanting to do the same on my bike. Talked to my painter and he said it could be done, but he didn't recommend it because the chance of it properly adhering to the raw metal is very slim.
You CAN put clear powdercoat on it though without any problems.
