Author Topic: BMW E21 Keihin  (Read 1425 times)
Offline Wilmo
BMW E21 Keihin
« on: December 22, 2014, 12:04:31 PM »
Hej all,
... And now time for something completely different. Sorry for having too much wheels, I have got an BMW E21 with an M10 motor with 1800cc. It is of course not a new car anymore and therefore it needs to be fun to drive it. My current Pierburg with a 25mm venturi is not a lot and therefore I am thinking of building in a Keihin from a Honda CB. And I need some help there.
I found a Keihin VB online: http://www.marktplaats.nl/a/motoren/onderdelen-honda/m876844534-honda-cb-carburateurs-keihin.html
Don't worry about the choking language, no info there. Only nice pictures.
I wonder how the choke works, is it manual? How does this one look? I wonder where the connections at the bottom are for. Is it for a back feed of petrol? Or is it vacuum?
Could you help me as well with finding the right jets? Or should I better forgot the whole project?
Greetings,
Wilmo
Offline Bankerdanny
  • Endeavor to persevere
Re: BMW E21 Keihin
« Reply #1 on: December 22, 2014, 03:23:20 PM »
Those are CV style carbs and use a butterfly actuated by a cable.
I think that you would be far better served to use one of the readily available Weber conversion kits for your car. Jets are easier to get and change, you won't have to attempt to fab up an intake, and there is a large community of E21 owners that will be able to give you proper tuning advice.
Re: BMW E21 Keihin
« Reply #2 on: December 22, 2014, 04:05:12 PM »
1+ for Webers, specifically a pair of 40 DCOEs, as were used on the BMW/Alpina.
Offline Bankerdanny
Re: BMW E21 Keihin
« Reply #3 on: December 23, 2014, 07:29:22 AM »
There are several motorcycle carb based setups available for British cars, Triumphs and MG's, and if you could find one of those that might be an option. But unless you have really strong fabrication and tuning skills doing it yourself will be a major challenge.
Offline jas67
Re: BMW E21 Keihin
« Reply #4 on: December 24, 2014, 07:34:09 PM »
For the 40 DCOE's, you'll need a cam, some headwork, and a matching exhaust to go with it.
There are also some 38mm side drafts available that are less radical, and could yield better results with a closer to stock engine.
You'll definitely want to consult with some BMW car forums before spending money on this one.
Are you a BMW CCA Member?   There are some forums on the BMW CCA website.
Classic Honda:
1976 CB400F
1975 CB400F (project)
1975 GL1000
1968 CL175 (1 nice one, one project)
1967 CB77
1967 CB160 (2 of 'em, both projects)
1967 CL160 project
Triumph: 2017 Thruxton R
BMW: 2016 R1200RS, 1975 R90S, 1973 R75/5, 1980 R100S
Ducati: 2013  Monster 796, 2013 848 Evo Corse SE track beast, 1974 750GT, 1970 Mk3d 450, 1966 Monza 250
Moto Morini: 1975 (titled 1976) 3 1/2 Strada, w/ Sport clipons.
Moto Guzzi: 2017 V7III Special,  1977 Le Mans, 1974 Eldorado
