Author Topic: advancer shaft on 750  (Read 2037 times)
DH
« on: December 23, 2014, 08:38:16 PM »
Whats the best way to get one out that is real tight?
Anything special? Thanks.
Offline bjbuchanan
Re: advancer shaft on 750
« Reply #1 on: December 23, 2014, 10:16:06 PM »
I have a pair of vice grips that are the parallel jaw type. I tape them with a wrap of duct tape and clamp close to the block  as possible. I do t like the double nut because it is to easy to twist that flimsy shaft.
with the pliers wrapped and a firm straight on twist they always come loose without marring the shaft
« Reply #2 on: December 24, 2014, 08:58:58 AM »
wide 6mm nuts are a big help if you double nut it.  get them real tight
use the closed end of a box wrench on the inner nut to prevent bloody knuckles.
light taps from a hammer on the end, under removal pressure, will help break it free.
careful to not bend it.
DH
« Reply #3 on: December 24, 2014, 11:05:27 AM »
Thanks guys, got it finally. did the tape thing. It had never been out. groaned, and broke loose.
tried the 2 nut deal first, but as flybox wrote, they need to be wide. Again, thanks.
« Reply #4 on: December 24, 2014, 11:11:04 AM »
nice.  replace that o-ring.
« Reply #5 on: December 24, 2014, 11:16:37 AM »
Do you have a source for that o-ring?
6 X 2.3  91301-300-000 has been DC'd by the Big Red Honda Machine
« Reply #6 on: December 24, 2014, 11:36:17 AM »
I used this 6x2.2
http://www.theoringstore.com/index.php?main_page=product_info&cPath=368_12_610&products_id=19508
DH
« Reply #7 on: December 24, 2014, 02:08:44 PM »
I will use that information if needed definately. I am on my way tearing it completely
down, and am planning on master gasket and seal set from cyclex. Not sure if it comes with that particular o ring or not. This isn't the first necessary part during
tear down that I'm gonna need later. Had to destroy the oil pump screen, wich is no longer made too.  >:(
Offline C5paul
    • C5 Performance
« Reply #8 on: December 24, 2014, 02:42:34 PM »
I have new o-rings (Viton) and shafts if anyone destroys them.
Offline MiGhost
  • What was that about being an
« Reply #9 on: December 24, 2014, 06:32:34 PM »
Elan has the oil pump screens available with the pressure spring kit in the parts for sale section.
~ Ghost
Grey Ghost '80 CB650C: Updated Stock Restomod. Period Custom Cruiser (OEM harbags & trunk, Wixom Ranger fairing, Jardine turnouts)
Bad Moon '83 XJ750MK Midnight Maxim: Full Dress Tour Deluxe w/ X-1 Fairing
DH
« Reply #10 on: December 24, 2014, 06:41:02 PM »
And wouldn't you know I only bought the basic kit earlier this year.... :(
