Author Topic: thoughts on engine bearings w/pics  (Read 593 times)
DH
« on: December 28, 2014, 08:50:48 PM »
These are from my 750 k5. I understand that plasti gauge is in order here, but wanted to get others thoughts and comments first. I only had this engine open to replace the 3 chains and re-seal/gasket, along with the tensioner assys. The crank and cam journal surfaces are all silk smooth. The only concern i have, if it can be considered one, is, do the main bearings look ok to reuse in their present condition? The engine is original with 53000 miles.
(Notice the shiny spots in some areas) sorry for maybe a rookie question, just not familiar with the bottom end of one of these. The bearings are not scored in any way as well. I'd like to re assemble as is, and not have to sterilize the crankcase and associated parts just to check bearing clearances if I don't have to. All parts have a nice even, coating of clean shell Rotella, changed evey 1500 miles, and show no signs of oil starvation. I am going to service the oil pump while in there. Also, do any of you clean used bearings, and if so, what do you use?
Online dave500
Re: thoughts on engine bearings w/pics
« Reply #1 on: December 28, 2014, 11:28:57 PM »
they look fine.
Offline Skowinski
« Reply #2 on: December 29, 2014, 10:36:44 AM »
I'm rebuilding a 71 CB500.  The main bearings look similar to those.  I checked the clearances with plastigage and they were well within the specifications, no problem.
DH
« Reply #3 on: December 29, 2014, 02:06:05 PM »
I'm guessing the shiny areas of the bearing surfaces is normal? Interesting, I've never seen that condition before.
Offline Whaleman
« Reply #4 on: December 29, 2014, 04:10:06 PM »
Look normal. If you are rich go ahead and replace. If not these will go another 100,000 miles. Dan
DH
« Reply #5 on: December 29, 2014, 07:33:43 PM »
Good enuf for me. Thanks folks. :)
