Author Topic: 1975 cb550 oil strainer  (Read 902 times)
Offline natron602
« on: December 29, 2014, 01:12:18 PM »
Ok guys. I'm finishing up my rebuild and knowing a bit more than at my first oil change I inspected the oil strainer. I'm having trouble getting a clear idea of what should be part of the assembly but I should have a spring and oring where the main shaft from it connects right?
As it is,I have neither but do have a metal ring around it that doesn't seem to fit there and I can't find mention of. I'll try to attach pics but that never seems to work well from my phone. Thanks.
Re: 1975 cb550 oil strainer
« Reply #1 on: December 29, 2014, 01:20:25 PM »
no o ring no clip,lose that metal ring,the sump holds it up and the little hose that feeds the counter shaft,that ring looks to be from the starter clutch needle assembly maybe?is it #10 in this picture?
« Last Edit: December 29, 2014, 01:25:35 PM by dave500 »
Offline natron602
« Reply #2 on: December 29, 2014, 03:49:16 PM »
Much too small and only 4mms.
« Reply #3 on: December 29, 2014, 04:15:01 PM »
ok whatever it is it don't belong there,not one of those oil pump o ring seats is it?#6?looks too shallow?
« Last Edit: December 29, 2014, 04:18:01 PM by dave500 »
Offline natron602
« Reply #4 on: December 31, 2014, 11:56:05 AM »
Yeah.it's just really hard to tell from the drawings. For now I'm happy enough to know it doesn't go where it was. Thanks a lot!
« Reply #5 on: January 01, 2015, 12:25:39 AM »
keep it in case,sure it came out of the engine not from another box of parts?
« Last Edit: January 01, 2015, 12:34:45 AM by dave500 »
Offline natron602
« Reply #6 on: January 03, 2015, 04:22:25 PM »
It was literally right there where it is in the picture when I took off the oil pan. The PO obviously didn't trust Japanese engineering and added his own touches.
