Author Topic: Brodie-Glide GL 1000 front end.  (Read 947 times)
« on: December 29, 2014, 07:25:50 PM »
Check this out.. Just put it together..see how it looks.  Paul Brodie from Brodie bicycles. Built these trees for his Vincent..long ago.. (FunJimmy may know him)
 Offset is 44.5 or 45 mm..anyone know what stock early GL is?
 Center to center is a 199.1 mm.
« Last Edit: December 29, 2014, 11:55:54 PM by 754 »
Re: Brodie-Glide GL 1000 front end.
« Reply #1 on: December 29, 2014, 07:28:07 PM »
He called his stuff ELS back then..
 Its not  6061 or 7075. It's ELS   :o
« Last Edit: December 29, 2014, 07:37:53 PM by 754 »
« Reply #2 on: December 29, 2014, 07:34:48 PM »
ELS!!! LOL!!! ;D
Offline Lostboy Steve
« Reply #3 on: December 30, 2014, 09:15:54 AM »
lol thats awesome.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline BPellerine
« Reply #4 on: December 30, 2014, 09:51:36 AM »
got a spare axle and speedo drive if you need,also found out that 78 calipers will fit ,same as f2,f3,small mod to 75,76 caliper mounts.bill
1978 CB 750K ard and webers
another anfob
Offline JohnN
« Reply #5 on: December 31, 2014, 06:04:52 AM »
754:
 GL1000 offset is 45mm.
Paul is building motorcycles these days. Check out his website at www.flashbackfab.com if you are in the market for a new Excelsior!
John
CR750 replica
CB750K2
85 VF500F
66 CA160
67 CT90
2000 Triumph 955i
69 Triumph Bonneville
« Reply #6 on: December 31, 2014, 08:23:46 AM »
Might need axle, i have the drive tang for speedo drive, I would think drive is same as 750?
The width, remeasured appears to be 198.5 mm. I looked online but could not find the early GL width?
Offline BPellerine
« Reply #7 on: December 31, 2014, 10:07:35 AM »
I will check Frank my forks are assembled ,easy to measure.bill
another anfob
« Reply #8 on: December 31, 2014, 10:11:38 AM »
Axle with this would be about 9 3/8 -9 1/2..looks like..
Offline JohnN
« Reply #9 on: December 31, 2014, 10:22:04 AM »
My GL1000 axle is about 10-1/4". I'm running a CB750 hub which fits using the axle spacers from the GL. Speedo drive is interchangeable as well.
 I also found that '81 GL1100 calipers fit the early holders. They are one piece with 43mm pistons in lieu of 38mm. They are also lighter than the two piece originals.
CR750 replica
CB750K2
85 VF500F
66 CA160
67 CT90
2000 Triumph 955i
Offline BPellerine
« Reply #10 on: December 31, 2014, 04:37:39 PM »
the gl speedo drive is thicker so wont fit 750 forks,my forks for 75 gl are 6.5 ins at bottom inside to inside.bill
another anfob
Offline Kevin
« Reply #11 on: December 31, 2014, 05:00:09 PM »
Pretty sure the "Expensive Lightweight #$%*' ELS logo is from Pete Aronson of Hyper-Formance.com in Tempe, AZ.
He has lots of products for the Kawasaki ZX11.
A couple of 400F's and a
'98 Suzuki Intruder VS1400 ~ for long rides
Offline Scott S
« Reply #12 on: January 01, 2015, 05:35:42 AM »
 And the ZRX. I have some of his stuff on my ZRX1100.
http://kwickstand.net/Hyper-Formance.com/Welcome.html
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #13 on: January 01, 2015, 08:10:40 PM »
Naw, his logo is Expensive Lightweight Stuff, not #$%*. ;D There is a pic of former member climbingaz's kid on the advancer page; I'm guessing from just about the time of the first relay!? (For those that don't know, climbingaz (Shawn) carried Godzilla from New Mexico to Arizona.)
« Reply #14 on: January 01, 2015, 08:45:11 PM »
I think one is a take on the other.... But now I will call my aluminun number parts ELS alloy.. Or ELS T6
