Author Topic: Why are the front directionals on my '76 CB550F Super Sport two filament bulbs?  (Read 1267 times)
Offline timrichter9
Ok.
Bike is a stock CB550F SS from 1976.  Not currently running.
It is winter and I was tinkering and decided to check the bulbs out to make sure I had no bad ones.
Noticed that the front directionals have two conductor sockets and the rear have just one wire.
Was wondering why that is.....
Thanks
Tim
P.S.  I have missing carbs.  I know that there are different carb bodies (or sets).   What should be stamped on a correct set for my bike (I have a set stamped 69A that look right, but they came from my dad's estate and he had a CB550K and a CB500
Thanks
Offline tlbranth
Not familiar with your model but two of my bikes, the 1975 and the 2002 have running lights in the front turn signal but not in the back. So....seems it's a safety feature maybe?
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline timrichter9
That seems a logical answer....Thanks!
Offline mrfish2
  • I might be a
Carbs for some of the 550s:
75-77 CB550F -- 069A
76 CB550K -- 087A
74-75 CB550K -- 022A
So if you're sure yours is a 76 F model then the 069A's are the right carbs for your bike
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline Bankerdanny
  • Endeavor to persevere
All 550's  in the US used the front turn signals as running lights as well.
Offline bjbuchanan
Front signals are used as running lights on US bikes, front only.
As for carbs, use the search button and search keihin I.d. chart. I would link for you but I'm on my phone
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Thanks
Tim
All of the lenses are amber. Most places require rear running lights to be red, so only the front facing amber lenses can be legally used as running lights in most places (here in the states anyway). I've got some red lenses for mine and plan to convert my rear (amber) turn only lights to dual filament running lights/turn signals (red) as well.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
