Author Topic: honda cb 500 motor botom end bearing oiling?  (Read 649 times)
Offline kranta
  • honda cb 250RS 1981 CAFE & honda cb 500 four 1978.
« on: January 03, 2015, 07:45:16 AM »
should i oil the transmission bearings and gears and crankshafts bearings/journals when i built bottom end??? or should i just put oil in motor before i start engine???
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=tf98mfde4gngf3le5ojcp0adb2&/topic,60973.0.html
Re: honda cb 500 motor botom end bearing oiling?
« Reply #1 on: January 03, 2015, 08:23:30 AM »
give it some oil vhen you test the shifting.
..but not aut over all...so the bond not can seal.
.just oil the rotating parts a bit to smooten the drive..so the testing of shifting is real good
i hate all this v-w.... vords
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #2 on: January 03, 2015, 08:35:11 AM »
Yes, lubricate items like bearings and gears when reassembling a motor.  There is specific stuff called 'assembly lube' made just for this job, but oil will do if you'll be running it again soon.
Offline kranta
« Reply #3 on: January 03, 2015, 10:37:15 AM »
ok, maybe i just buy that assembly lube. ;D but do i lubricate too transmission bearings and primary shafts bearings??
« Last Edit: January 03, 2015, 10:38:58 AM by kranta »
Offline Bodi
« Reply #4 on: January 03, 2015, 12:26:48 PM »
I would wet the bearings with motor oil before assembly, and have the oil seal lips lubed with light grease or oil as well. The assembly lube is, I think, for plain bearings - not ball or roller bearings.
The transmission doesn't need a lot of oil but won't be happy with none.
Offline kranta
« Reply #5 on: January 03, 2015, 12:46:46 PM »
ok, thanks.
