Author Topic: Service/Rebuild Of Mikuni/Solex PHH Carbs  (Read 9086 times)
Offline jaguar
Re: Service/Rebuild Of Mikuni/Solex PHH Carbs
« Reply #25 on: January 07, 2015, 03:41:42 AM »
Maybe the harley guys know something about them.
http://www.ebay.com/itm/mikuni-solex-phh-36-with-Branch-Intake-for-harley-chopper-bobber-/121537216229
Have seen a few set ups for a harley, so far none have ever run them or know much.
Offline Jim F
  • go baby go
« Reply #26 on: January 07, 2015, 10:20:49 AM »
I might be able to laser weld your choke arm if you want to try this
call me at 770-367-7320
Good luck
Jim
« Last Edit: January 07, 2015, 02:41:19 PM by Jim F »
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
« Reply #27 on: January 07, 2015, 12:29:55 PM »
In Webers the Harley, and Honda 4 kits, used the same jetting.
Offline jaguar
« Reply #28 on: January 11, 2015, 07:32:38 AM »
Got one response.
Sorry to say that that carb is a red-headed step child. The only items availble today that fit are listed below.  This carb was a specialty item for Bikes and smaller motors and the factory support for it went away over 25 years ago. I did have one sent to me to compare parts, got a good close look and there are some similarities and alot of big differences.  Intermediate jets are called Pilot jets, no main or fuel jets we have will fit.
Similar/same parts:
accel pump diaphragm ($25)
air jet  ($4 ea)
pilot jet   ($4 ea)
pilot screw (Idle screw)   ($7 ea)
throttle shaft seals ($1.50 ea), collar and washer and nut ($2. ea)
inner venturi gaskets ($1.50 ea)
needle/seat  ($25 ea)
Everything not listed above is special or incompatible with all other Mikuni PHH style automotive sidedraft carbs.  The carb form factor is smaller so will not bolt to existing manifolds that all other sizes match up to.  Also because of the smaller form factor, it uses special float chamber gaskets, float ass'y, jet chamber cover and gaskets as well as smaller jet holder tubes, inner and outer venturis.
Sorry for the bad news, wish I could be of more help.  It is referred to as a Type Q 36mm or PHH2/36.
Todd Walrich
Wolf Creek Racing
