Only sealant where the cases have contact with each other
I have done too much back in the days with sealant drops later on clogging the oil pump metal filter. No problem since I cleaned the filter (mesh) but I'm not sure if it can reach the oil channels in the top end.
One more thing: Do not use Hylomar blue as sealant between the cases. It WILL leak! I got that information from a friend back in the days that had done several engines . I did not follow the advice and the cases were leaking. Not much but always dirty engine. Hermetite Golden did work very well back in the days, now not available anymore.
I used Hondabond on case halves last time (2013) which seems to be very good. Too good as sealant on paper/fiber gasket when its like a glue. I had to scratch the head cover + head clean for an hour or 2 when open it. New gasket with Permatex copper spray that make it possible to open head cover again and again with same fiber gasket,
Permatex Copper spray gasket work well on fiber gaskets as extra sealant. I used as extra ensurance on cometic fiber head gasket.
