Author Topic: To cut or not to cut?  (Read 1468 times)
Offline AlekStooge
  • can't afford cheap stuff
« on: January 07, 2015, 09:40:11 AM »
Hi, just started disassembling my CB550. As I started taking the rear fender off, I didn't know what the best way to handle electrical components was. Should I cut the wires and get new ones or should I keep the originals?
Where would I be able to get a whole wiring kit for my 78 CB 550? What the best way to go about this.
Thanks
Offline Bankerdanny
  • Endeavor to persevere
Re: To cut or not to cut?
« Reply #1 on: January 07, 2015, 09:59:23 AM »
There is just no need to do this. This isn't a car with lots of nooks and crannies and a firewall or a modern bike with tons of electrical connections and sensors.
Removing the whole loom intact should take an hour or so.
You shouldn't need a new harness, but I would go to Vintage Connections link: http://www.vintageconnections.com/ and order his professional kit CK1 with the crimper. Then during reassembly replace connectors as necessary.
Offline Vinhead1957
« Reply #2 on: January 07, 2015, 10:00:23 AM »
Keep the original as intact as possible. Even is you replace it can be used as a reference for the new one.  There are a couple suppliers, but I have not bought one.  I replaced the connectors with vintage connected supplier.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: January 07, 2015, 10:39:08 AM »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline AlekStooge
« Reply #4 on: January 07, 2015, 04:34:04 PM »
Thanks to those who were helpful.
