Author Topic: Checklist for First Start-up after Rebuild  (Read 6582 times)
Offline Lazerviking
  • I need help
Re: Checklist for First Start-up after Rebuild
« Reply #25 on: February 02, 2015, 08:51:56 PM »
Update time;
I have replaced the kill/start switch with a new one from 4into1.com and while I was doing that I replaced the handle bars(euro style) and the front brake/master cylinder(wasn't stock but an ugly after market one, I replaced with replica version from 4into1). It's looking pretty with new grips too. I only wish I replaced the turn signal/lights mechanism so they matched but oh well, not made of $.
I ended up pulling the engine and cracking the cases to examine the kickstart spring issue also. I installed it wrong. Oops. It's definitely much happier now and the engine is back together and back in the frame already. Tomorrow I'll put the rest of the components back on, tweak a thing or two and see if I can get her fired up.
Wish me luck!
Offline mark52
  • 1975 cb750 k5
« Reply #26 on: February 03, 2015, 07:00:05 AM »
Lazerviking, good to hear that you where able to fix your kickstart problem. I still can't figure out how to get the spring on correctly in my motor. Can you share how you went about getting the spring in correctly, Thanks
Mark
Mark
« Reply #27 on: February 03, 2015, 07:20:53 AM »
Update time;
Wish me luck!
I like your spirit!  Good luck.
Offline Lazerviking
  • I need help
« Reply #28 on: February 03, 2015, 08:37:25 AM »
Mark
Might be difficult to explain through text. It also helped having a second person but now that I've done it once I could do it by myself.
You want to assemble the kickstarter spring, gear, pawl and spindle in its posisition in the bottom case. Once you have them in position ou should be able to see where both ends of the spring want to rest. The straight end of the spring sits in the hole/channel of the pawl and the hooked end of the spring want to hook in the channel of the case towards the front. Also notice the pointy end of the pawl that protrudes, that rests in the cases underneath a metal pin located below the channel where the hooked end o the spring rests in the case. The trick is getting a screwdriver in there in order to hook the pawl against the pin in the case and simultaneously pull the hooked end under the spring up to land in its channel in the case. The spindle cannot be pushed into place all the way while this is happening be wise you need some room/play to force everything into place. Once the pawl is against the pin and the hooked part of the spring is in its channel in the case you can slide the spindle all the way into its position and that should hold everything together.
Once you have it installed currently you will know. You can put the kickstart arm on and test, but make sure the little locking dowel/pin is in. Don't want all your hard work to pot out.
Hope this helps. It's probably confusing but once you get it youll see its not too bad. Just takes a little finesse.
Offline mark52
  • 1975 cb750 k5
« Reply #29 on: February 03, 2015, 12:15:06 PM »
Thanks Lazerviking, I'll work on it again tonight, what a b*&*$!!! Glad yours is back together and working as it should.
Mark
Offline restobiker
    • Restoration Biker
« Reply #30 on: March 07, 2026, 09:26:05 AM »
Old thread I know, but someone searching for how to diagnose the starter issue should know that you can apply 12 V to the wire that is colored yellow and red directly from the battery. Then ground the green red wire. if you do not hear the solenoid click, begin tapping it with a small hammer and it will probably engage. The starter should immediately crank over the engine. Solenoids that sit for a long time are prone to sticking and simply need vibration when energized to release them.
Offline newday777
« Reply #31 on: March 07, 2026, 10:07:40 AM »
Welcome aboard the forum from southern NH.
Introduce yourself and your bike(s) in the new members section.
Stu
My current rides
Prior bikes....
