Author Topic: GV1390's Trattoria "Racer" V2!  (Read 83485 times)
Offline riverfever
Re: GV1390's Trattoria "Racer" round 2!
« Reply #125 on: November 23, 2015, 04:45:16 PM »
I really like the way your project's coming along. Tank turned out great.
Offline GV1390
  • Express Gratitude.
« Reply #126 on: November 24, 2015, 03:28:27 AM »
Thank you, it's much appreciated! :)
08' Ducati S4RS, 71’ CB500, 71' CL350, 72' R90/6, 16' Ural Gear Up & 02' ZRX1200R.
Offline eoddom
« Reply #127 on: November 24, 2015, 01:45:14 PM »
Where did you get those rear set brackets?  They look like the bolt right on?
Offline GV1390
« Reply #128 on: November 25, 2015, 04:48:00 AM »
Bought them from Coginto Moto. Added some aesthetics to them and needed some work for them to work for my setup.
Offline GV1390
« Reply #129 on: November 25, 2015, 04:48:20 AM »
Oil filter relocation, done!
Offline GV1390
« Reply #130 on: November 30, 2015, 04:30:23 AM »
Between Saturday night and all day Sunday the following was done:
Shifter side done, tail light mounted, internal throttle assembled, coil packs and rear reservoir mounted, kickstand modified, muffler tag holes welded/sanded down, fancy C5 ignition system install initiated. Can't thank my friend Christian (@Newman on here) enough throughout this entire build, he's been really coming through as of late. Stoked to see how it's panning out so far!
« Reply #131 on: December 07, 2015, 11:38:11 AM »
So GV,
What do you have left on your punchlist for this build.  It looks pretty close.
Offline GV1390
« Reply #132 on: December 07, 2015, 11:57:29 AM »
So GV,
The list never ends somehow....sigh.
-Finish up the ignition install, had to get some different NGK boots for routing (insert OCD here)
-Scratch built complete harness
-Clutch cable
-Starter delete plug
-Under tail aluminum cover for aesthetics and to retain my R&R combo unit
-Rear fender
-Swap in a bunch of nice SS hardware
-Mount seat
-Find alternative petcock with carb clearance
-Modify rear brake rear-set for kicker clearance
Just a quick list for now, even though theres tons of other tasks on the list. I have a 61.5mm piston kit that was supposed to go in but, I may just build the spare 550 motor to throw in eventually.
Still researching a different caliper and rotor setup. Was looking into the newer style GSXR Brembo calipers and a Brake Tech floating iron rotor but not sure yet. Also looking for shorter levers that'll also work with my MC.
Offline GV1390
« Reply #133 on: December 07, 2015, 12:08:24 PM »
Hi Cal!
Do you happen to have a picture of your kicker, just out of curiosity that is.
Let's not forget I'll have a neutral and oil light as well that require some wires! :)
Noted, thanks!
« Reply #134 on: December 07, 2015, 12:24:15 PM »
Watch out or he might want the signal beeper, too!
« Reply #135 on: January 14, 2016, 11:26:47 AM »
Are you looking for one like this ?
Left and right at bottom , fits the starter hole..
« Reply #136 on: January 14, 2016, 03:43:21 PM »
Are you running fenders?
Offline Trad
« Reply #137 on: January 14, 2016, 08:04:54 PM »
Frank, He sure is. I really like the two I bought from you. Buy one from Frank GV.  ;D
I think he's running a rear fender Don, it was on his list.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline sethmcalister
« Reply #138 on: January 15, 2016, 04:47:57 AM »
GV, can you give more details of what you did for your internal throttle, please?
Sent from my Nexus 6P using Tapatalk
Offline GV1390
« Reply #139 on: January 15, 2016, 05:34:22 AM »
Pm'd you back, I'll take one.
Offline GV1390
« Reply #140 on: January 15, 2016, 05:34:50 AM »
Si. We've exchanged thoughts on this, hopefully something decent comes up of it.
Offline GV1390
« Reply #141 on: January 15, 2016, 05:35:40 AM »
Offline GV1390
« Reply #142 on: January 15, 2016, 05:40:18 AM »
It's a helix that converts rotation to linear movement, roughly 45 degrees.
Sorry for not multi-quoting everyone into one post, whoops!
Offline GV1390
« Reply #143 on: January 15, 2016, 05:43:44 AM »
Noted! Thanks Cal.
Anyone construct aluminum fenders for these? Seeing what options are. I'd really like just a hugger out back and something minimal up front.
Offline jerry h
« Reply #144 on: January 16, 2016, 10:43:57 PM »
Really enjoy watching your progress.....  lots of nice ideas. ;)
Offline GV1390
« Reply #145 on: January 18, 2016, 05:22:51 AM »
Thank you sir, glad someone enjoys it! :)
Offline GV1390
« Reply #146 on: February 05, 2016, 07:36:15 AM »
A little update for those interested....
I made the seat bracket and tabs, had a friend weld on the tabs for me.
A few crappy iPhone pics:
Ditched the exhaust setup as I'll be running a Ripple Rock Racers Hindle setup from my buddy Kemp.
Still have the following to do:
*Fabricate a rear ventilated aluminum panel under my seat cowl for R&R placement
*Complete wiring harness from scratch with supporting diagram
*New triple trees with corrected offset - which means new holes for indicators, re-make an ignition switch bracket and also add turning stops
*Decide what tank emblems to run
*Address kick start lever issue as it interferes with my rear brake rearset
*Finish the front portion of my seat mounting
*Clutch cable
*Make a rear tire hugger "fender"
*Bleed front brake, add fluids, double and triple check all bolts, adjust valves, etc
Kinda torn if I want to run a 1/4 or 1/2 fairing....I don't in a way as that's the typical Cafe Racer theme and also because I don't want to take away from the awesome headlight I'm running. Maybe I'll use that as an excuse to build my other CB550F.
« Reply #147 on: February 05, 2016, 07:59:33 AM »
Why do you want to run a fairing? Track?
Offline GV1390
« Reply #148 on: February 05, 2016, 08:03:46 AM »
I like the idea, aesthetically.....with that being said, I will track it just to do it once, won't be a track bike by any means though. I just don't think I can stomach taking away from my awesome headlight, don't want to hide it with a fairing.
Offline sinister902
    • Anger Street Kustoms
« Reply #149 on: February 05, 2016, 08:34:22 AM »
if the front end looks to light to you, maybe try a very small fender painted the same color as the tank to pull some of the main color up front.....could paint the bucket too, but I like that the headlight is stainless steel and might hurt to paint over it. those are all I'd really consider....except maybe like a bikini style fairing just over top of the headlight...
