Author Topic: GV1390's Trattoria "Racer" V2!  (Read 75395 times)
Offline Camrector
Re: GV1390's Trattoria "Racer" round 2!
« Reply #175 on: February 08, 2016, 09:08:13 AM »
"Buy it right the first time."  GV1390
This must be exactly what's going on then. Interesting that you would be buying parts for a nonexistent motor than the one that you have. Paint the wall before you paint the trim bud.
Offline GV1390
  • Express Gratitude.
« Reply #176 on: February 08, 2016, 09:12:08 AM »
Believe nothing of what you hear and half of what you see.
« Last Edit: February 08, 2016, 09:13:52 AM by GV1390 »
93' GSX-R1100, 78' CB550, 71' CL350, 71’ CB500 & 02' ZRX1200R.
Offline GV1390
« Reply #177 on: February 08, 2016, 09:13:12 AM »
Exactly as I pictured you. Got to love selfies!
Thanks not a selfie, sir!  8)
This is:
Perhaps of your father. I'm quite certain you don't have enough hair on your face (let alone other areas) to support a beard  8)
I wish that were the case! Italians aren't known to be hairless! :/
Offline GV1390
« Reply #178 on: May 04, 2016, 04:38:40 AM »
This will be getting updates soon.....but in the meantime.....
@Sinister902 and myself have been working on a "cafe" CB550 for a friend of mine, turned out decent:
Will be getting wrapped up this week, stoked considering how quickly it came together.
« Last Edit: May 04, 2016, 08:21:32 AM by GV1390 »
« Reply #179 on: May 04, 2016, 06:37:33 AM »
How do you like the Hindle?  Not a fan of that big branding on it.
Offline GV1390
« Reply #180 on: May 04, 2016, 06:51:14 AM »
I absolutely LOVE the Hindle, especially it's service through Kemp @ Ripple Rock Racers. I will post sound clips on the weekend once I take it on a test ride.
Offline sinister902
    • Anger Street Kustoms
« Reply #181 on: May 04, 2016, 08:19:33 AM »
the hindle fits like a glove, is super light due to the stainless construction, and the note it yells is absolutely superb. The branding is stick-on, not riveted....could come right off on the non-coated exhausts and be plain stainless throughout....
thing is fairly quiet down at idle and quarter throttle, but grab all of it and she screams.
« Reply #182 on: May 04, 2016, 08:25:30 AM »
Alright already, GV. Enough teasing.  Now let's see your update!
Offline GV1390
« Reply #183 on: May 05, 2016, 05:01:16 AM »
Who doesn't like a little teasing though? :)
« Reply #184 on: May 05, 2016, 09:16:53 AM »
GV,
Did you source your custom offset triples?  If so, did you go with Cognitomoto?
You also mentioned adding a rear hugger.  Did you have something fabricated or adapt a fender?  Or still "to do"?
Offline GV1390
« Reply #185 on: July 28, 2016, 08:18:35 AM »
This should get an update, eh? Life has been pretty hectic as of late, so this doesn't get the attention it deserves but anyway....
Had some fun track time on the MV:
Added one of these with two indicators built into the top triple:
Two indicators as such (oil and neutral):
Also a set of these:
Under seat tray made out of aluminum:
I didn't like the chincy look my seat had....a few months back I decided to stop by a friends place to see what he could do with it. I told him what I wanted and he nailed it. Some Italian leather and suede action:
Will need to make a different headlight mount due to the relief cuts in my new lower triple:
Spent a TON of time on wiring this thing from scratch:
Made a quick and easy ignition relocation bracket just to get the wiring done. Will end up making it look nice and paint it as well:
Offline GV1390
« Reply #186 on: July 28, 2016, 08:26:41 AM »
Got to hang out with Kemp again when I picked up my exhaust. Awesome guy.
« Reply #187 on: July 28, 2016, 10:19:10 AM »
Inspired by another Italian?
« Reply #188 on: July 28, 2016, 10:24:05 AM »
Some great stuff here Gennaro.
I like the lighter weight version of the Cognitomoto electronics tray, and your inset neutral/oil pressure LEDs in the top triple.
The leather upgrade to the vinyl Motolanna seat looks pretty awesome, too.  I had the same idea in mind for my spare Motolanna seat, but was debating leather/Alcantara.  Thanks for the input on Alcantara durability.
Oh, and way to get that knee down!!
Offline GV1390
« Reply #189 on: July 28, 2016, 10:30:33 AM »
Bravo! :)
Offline GV1390
« Reply #190 on: July 28, 2016, 10:30:55 AM »
Thank you for the kind words, as always, sir!
Offline sinister902
« Reply #191 on: July 28, 2016, 11:03:15 AM »
soon she will voice her first bark. :)
Offline GV1390
« Reply #192 on: August 01, 2016, 04:17:33 AM »
Had a friend of mine do some welding on my Hindle as it needed a little massaging for my application...
oh yeah and IT RUNS!!! Started up first kick, super stoked. Looks like I'll be pushing to get it done within the month to make some shows before the season ends.
Offline sinister902
« Reply #193 on: August 01, 2016, 05:12:50 AM »
What was the issue with the "no start" previously?
I stopped by to help out, I started checking valve clearances and after I had done three of them I realize that his .05mm and .06mm were stuck together with what looked like a tiny tack weld from something like arcing out across a battery or something. so all of his intake valves were over double the clearance and I think two of the exhaust ones were a little tight. I also completely removed the C5 ignition and set the motor to TDC with the stock advance unit, then locked the crank with a wrench on the stator side, and set the C5 TDC with it locked. Then I did the blow-into-an-overflow-tube trick to push a splash of fuel into the intake tract and GV gave her a solid boot and she came to life.
We shot video, can't believe he didn't upload the video!
Offline Ericcb750
« Reply #194 on: August 01, 2016, 06:36:43 AM »
This bike is coming out awesome, when the time comes for another bike I think i'll be looking to a 550. Never rode one but they seem like such a nice middle ground between the power of the 750 and the handling/nimble-ness (probably not a word) of the CB350. Keep up the good work....
1978 CB750K
1978 CB750F super sport
2005 Sportster 1208
« Reply #195 on: August 01, 2016, 07:02:20 AM »
GV,
I imagine that was either Kemp doing the alternations) to the exhaust.  Was that to accommodate your swingarm?
Offline GV1390
« Reply #196 on: August 01, 2016, 08:15:09 AM »
Valve clearances... sounds familiar  >:( 8) I guess I should be expecting a substantial shipment of dollars or donuts soon, eh?
Donuts from an Italian? hmmmm.
Offline GV1390
« Reply #197 on: August 01, 2016, 08:15:54 AM »
Thanks man! I PM'd you back, glad you're making the switch. :P
Offline GV1390
« Reply #198 on: August 01, 2016, 08:18:43 AM »
GV,
Kemp did not make the alterations although he does think it looks "hot" haha. :) Yes, it was to accommodate my swingarm....also, as I don't have passenger mounts any longer I had to come up with a solution for mounting the muffler. Since the front section has a slip-fit with springs, I wouldn't be able to just leave it hang with only springs. Instead I came up with the idea to weld the rear section and also weld on a mount using the same bolt my rear master shares. Stoked with how it came out.
Offline GV1390
« Reply #199 on: August 01, 2016, 08:19:56 AM »
Then I'll just take the $$$$. Makes it easier. 8)
Starbucks gift cards on zee way.
