Author Topic: GV1390's Trattoria "Racer" V2!  (Read 73412 times)
Offline calj737
  • I refuse...
Re: GV1390's Trattoria "Racer" round 2!
« Reply #250 on: August 02, 2016, 01:06:47 PM »
Nice. Get a fan blowing across that motor!
« Reply #251 on: August 02, 2016, 03:41:38 PM »
GV is my favorite person in the whole world!!!  :-X
Awwwwww, I'm flattered! Always knew you had a heart buried deep beneath that thick yet callous skin of yours!
 :D
Callused or callous?
callus Callous as in cold hearted lol. FTFY
Typing > me.
Or simply Cal-ussed.  ;)
Brilliant!
Offline GV1390
  • Express Gratitude.
« Reply #252 on: August 04, 2016, 09:55:21 AM »
Work. In. Progress.
andddddd, a random lunch date with my Italian woman:
Still a ton to do, it's the little things that take the longest. -_-
93' GSX-R1100, 78' CB550, 71' CL350, 71’ CB500 & 02' ZRX1200R.
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #253 on: August 04, 2016, 10:08:15 AM »
She's a beaut, Clark!
I'm sure I could find this if I looked back, but did you use a different color on the covers than on the case? Clutch cover looks darker than the case.
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline GV1390
« Reply #254 on: August 04, 2016, 10:21:46 AM »
Thank you, sir!
Yeah, I had most of the covers powder-coated in a "hyper black" which is a dark grey. The short block is painted high temp ceramic grey engine paint. The head is raw.
Offline GV1390
« Reply #255 on: August 04, 2016, 10:36:45 AM »
Those pictures kinda make me half torn again on black vs gold forks.
-_-
Offline joeyvans
  • Definitely not a
« Reply #256 on: August 04, 2016, 10:47:54 AM »
GV... IMHO.... Once your beautiful stainless headers turn a nice gold color... I think you are going to like your current forks.
1976 CB550 K2
Offline riverfever
« Reply #257 on: August 04, 2016, 11:39:06 AM »
Best quote ever.
And GV....bike looks great but, forgive me, what is the cylinder you're holding?
Offline GV1390
« Reply #258 on: August 04, 2016, 11:43:38 AM »
Best quote ever.
My MC reservoir. Decided to come up with that instead of using a regular hose with cap on top. Sinister902 turned it for me.
Cal or anyone else who has the experience; please do tell me how my geometry is "jacked" as I'm sick of being told this. This week I will be measuring neck angle, fork length to configure what the trail currently is vs stock so we can put this silly dilemma to bed.
Offline calj737
  • I refuse...
« Reply #259 on: August 04, 2016, 01:45:34 PM »
I can't quite picture what you're describing? That cylinder is your reservoir? For the front or rear brakes? If for the front, I'd be curious if it will hold sufficient volume to properly actuate your brakes. If for the rear, that's a bit more viable as its only actuation is to pull the drum rod.
Curious and mildly intrigued... :-\
Offline calj737
  • I refuse...
« Reply #260 on: August 04, 2016, 01:53:46 PM »
There are plenty of folks far more knowledgeable than I am with respect to geometry. But, my input/opinion is this: I have ridden lots of bikes over the past 35 years on the street, literally traveling nearly 500,000 miles on 2 wheels. I dare say, that among them, few ever shared the exact rake/trail numbers amongst them. Many were probably close, and there are solid, industry targets for differing types of bikes that are worth consulting.
Depending entirely upon the type of bike, its purpose, your riding style and habits, I don't know if you can create a bike from numbers that's "perfect". Many pro riders tweak endlessly for their style and preference, and of course track conditions. But thats on the track. Can you really ride on the street the difference in 0.5 degrees of trail? I am dubious.
Looking at your bike, the only thing that catches my eye is the aspect ratio on the rear tire (we've discussed since your choice for it) looks too tall. A taller diameter rear wheel than the front is not a good idea. Will it handle? Probably. Jeez, your entire bike is non-stock and upgraded on the handling/steering/braking fronts, so who's to say? Ride the darn thing, and tweak it as you go. Any "opinion" as to it being jacked up is conjecture in my opinion. Without measured numbers, how can anyone say for certain what the geometry will do? Its all cobbled together from other bikes.
Besides, what do "they" know; you have a steering damper installed  ;)
Offline sinister902
    • Anger Street Kustoms
« Reply #261 on: August 05, 2016, 05:47:08 AM »
when GV was ordering the 45mm offset triples I had him take some rough measurements..... at the time I did some math
if we are to assume the neck angle is stock (probably not but it's a starting point).....
stock trail is 4.1 based on this very site's info page.
with GV's setup assuming stock neck angle, his trail would be 4.45
playing with the neck angle number yields an change of .25" per degree of neck angle either direction. With the rear tire size, the worst case is probably realistically 2* which would put him just barely under 5" of trail or on the other side about 3.95"..... so, either the steering damper is gonna help with potentially fast steering, or it may need to be removed due to slightly slow and "heavy" steering. Regardless, as Cal says....it's going to be more than rideable. And at the end of the day, if it's some huge problem it's a simple rear tire change that's what.....$80-90?
Offline calj737
  • I refuse...
« Reply #262 on: August 05, 2016, 09:21:47 AM »
His neck angle and stem are stock, just the offset is different.
Offline 540nova
« Reply #263 on: August 05, 2016, 09:36:27 AM »
As opposed to this, which is all the rage these days
1974 CB450, 2006 CBR1000RR
Offline sinister902
« Reply #264 on: August 05, 2016, 02:08:57 PM »
with respect to the rest of the frame it is unchanged, but not with respect to the level plane it travels on....
it's measured to the perpendicular of the surface the wheels ride on....so with the rear having 1.48" more tire outside diameter and the front having .29" less tire outside diameter, the angle with respect to perpendicular to the ground will be different than 27*
Offline calj737
  • I refuse...
« Reply #265 on: August 05, 2016, 04:32:17 PM »
I see the point you're making, Nick  :) I interpreted your earlier post as a possibility his frame had been modified at the neck.
By the way, the frame you showed is a 750  ;) Just for clarification  :)
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #266 on: August 05, 2016, 05:53:10 PM »
It's obviously important to have a comprehensive understanding and respect for motorcycle geometry especially if you're building a competitive race chassis but this isn't a competitive race bike. The specifics mentioned above are viewed in isolation and do not take into consideration other aspects of the build. Primarily a reduction in fork offset. From your measurements the steering head angle will be reduced by approx. 1° which reduces trail. Trail is increased with a reduction in fork offset so one can easily offset the other but it's important to remember that frame geometry is a science based on compromises. Take a look at modern motorcycle specifications and you wil see that there isn't one perfect spec but many different approaches to the same end goal.
Offline GV1390
« Reply #267 on: August 08, 2016, 04:16:36 AM »
Another tire is $60....I can afford it lol. When originally ordering tires, I wanted the meaty look out back on purpose......knowing that, I may need to go down a size eventually - really not a big deal. 130/80 would still be a taller diameter than the 110/90....which 110/90 would be 99% and 130/80 is 104%. This specific build will still out handle any local CB550/500 show motorcycle around a track even with the tires on it now and I have no problem showing that.
Offline sinister902
« Reply #268 on: August 08, 2016, 05:08:12 AM »
stock tire sizes had 1.6% difference in diameter front to back, and 20% width difference front to back.... 110/90/18 up front and 130/80/18 out back is 1.5% and 18%.....super close!
« Reply #269 on: August 08, 2016, 09:20:22 AM »
Have you taken it out for a spin yet, GV?  I think you were still working on the charging system and a few details, right?
Offline GV1390
« Reply #270 on: August 08, 2016, 09:48:04 AM »
No spins yet, but surely soon! I will work on it this week when I get a moment...I just got back in town so work/school/martial arts/life takes first priority.
Offline sinister902
« Reply #271 on: August 08, 2016, 10:31:54 AM »
The antigravity battery has a standing voltage of 13.5v as it is, so it is really tough to say if the bike is charging or not
otherwise we need to get the tail sniffer on it and see where it's at on jetting before he takes it out for a spin to seat the rings. Very minor details left to iron out.
Offline GV1390
« Reply #272 on: August 08, 2016, 10:35:38 AM »
Don, all goes well this week then this thing will see a track day before the season is over. Speaking of track time; your buddies KZ swapped CB is so damn awesome. Love that he tracks that jam maker.
« Reply #273 on: August 08, 2016, 11:44:18 AM »
I rode it last year.  It weighs nothing and handles amazingly well.
« Reply #274 on: August 08, 2016, 09:59:20 PM »
Ok GV, get off you tuckus and get that bike completed.  If you get it done in the next couple of days, I think you could battle it out for the Upstate NY Beauty Contest.   ;D
