The SOHC/4 World Tour is in under way.
Bump.So after re-soda blasting it yet again, I removed the spare head/jugs I had on it, wire-wheeled it a bunch and pretty much soaked it in acetone before paint. Same paint was used, just with no primer this time and very light coats. Seems to be holding up pretty good so far.Re-ringed and cleaned the pistons along with a hone jobs on the jugs and started with the assembly.
Sounds pretty thorough. Any reason why you did not replace the stock cylinder studs with HD studs?
Quote from: CB750 Cafe Racer Fan on March 25, 2015, 08:04:33 AMSounds pretty thorough. Any reason why you did not replace the stock cylinder studs with HD studs?Don, sometimes it is more trouble than it's worth. After talking with Mike in depth on this, the majority of the time it's not needed. It add's a piece of mind when finished properly, but it can also open a can of worms without necessity.
Quote from: Trad on March 25, 2015, 04:28:18 PMQuote from: CB750 Cafe Racer Fan on March 25, 2015, 08:04:33 AMSounds pretty thorough. Any reason why you did not replace the stock cylinder studs with HD studs?Don, sometimes it is more trouble than it's worth. After talking with Mike in depth on this, the majority of the time it's not needed. It add's a piece of mind when finished properly, but it can also open a can of worms without necessity. I have left sleeping dogs lie on this before on my 750 (entire rebuild) and my 550 (top end gasket refresh). On my 550, after springing a base gasket leak, I said screw it and used a set of APE HD studs. Between the extra torque and new gaskets, the leak was eliminated.That said, I've had more than a few leak issues in the shakedown of my 750 (no base gasket leak, just valve cover leaks). I'm inclined to swap out the studs with an engine with an entire build, especially one using higher compression pistons and a higher performance spec motor.
Nice work Gennaro! What method did you use to get the cylinder over the Pistons? Also, when splitting the cam chain did you get the correct rivet/soft link from Honda? I would look at doing so man. The endless links on these factory chains aren't meant to be riveted back together.
Quote from: GV1390 on March 25, 2015, 05:30:44 AMBump.So after re-soda blasting it yet again, I removed the spare head/jugs I had on it, wire-wheeled it a bunch and pretty much soaked it in acetone before paint. Same paint was used, just with no primer this time and very light coats. Seems to be holding up pretty good so far.Re-ringed and cleaned the pistons along with a hone jobs on the jugs and started with the assembly. That watch looks very familiar - what brand/model it is ?
Looking good GV! Engine looks a treat, I'm glad its on the bench now & no longer hanging from the roof - made me cringe every time I saw it, haha.
Quote from: CB750 Cafe Racer Fan on March 25, 2015, 08:04:33 AMSounds pretty thorough. Any reason why you did not replace the stock cylinder studs with HD studs?Don, sometimes it is more trouble than it's worth. After talking with Mike in depth on this, the majority of the time it's not needed. It add's a piece of mind when finished properly, but it can also open a can of worms without necessity. Nice work Gennaro! What method did you use to get the cylinder over the Pistons? Also, when splitting the cam chain did you get the correct rivet/soft link from Honda? I would look at doing so man. The endless links on these factory chains aren't meant to be riveted back together. All in all, I really dig how the engine looks. Props on getting it done so fast. Leaving me in the dust. haha
Looks #$%*ing Killer Gennaro. Keep it up!
Are you not planning on running a steering stabilizer either? I ask because I notice you altered the lower clamp for your headlight mount, and in the final picture the top side is also tapped?The geometry changes of the gsxr front end on the stock bike does promote the chances of tank slappers, especially since you are now running single-sided brakes.Food for thought-
Sorry, my question about the tapped hole was on the top of the bottom clamp in the picture. Where you posted the new VIN tag. Is that a modification for a different steering stop perhaps?
The paint on the frame looks so slick. Where did you get the replacement vin tag?
Those replacement VIN tags are pretty close. I try to save mine and re-rivet when possible.
