Author Topic: Looking to replace the bulb inside a sealed beam unit  (Read 1462 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: January 14, 2015, 08:01:16 AM »
I've heard of this being done before - somehow cut a hole in the back and remove the bulb, and then insert a replacement bulb & socket. Anybody done this before? How did you do it?
Offline Bankerdanny
  • Endeavor to persevere
Re: Looking to replace the bulb inside a sealed beam unit
« Reply #1 on: January 14, 2015, 12:53:59 PM »
There is a kit to convert a conventional sealed beam to LED that works like you describe. Somebody on the forum posted about it within the last month or so.
If you want to stay with halogen, then I would just by the H4 conversion. I put on on my Royal Enfield and it was an easy swap, no more difficult than replacing the sealed beam unit.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #2 on: January 14, 2015, 01:06:02 PM »
This is for our C200 we're using in the $500 challenge, so budget constraints are an issue - which is why I'm looking into chopping up the stocker. Proper replacements are around $45 :(
Online seanbarney41
« Reply #3 on: January 14, 2015, 01:52:39 PM »
Lots of threads about this over at HondaTwins.net...where they ride lots of bikes with little 6 volt headlights that there is no available H4 conversion
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #4 on: January 15, 2015, 10:58:21 AM »
^Thanks for the tip
« Reply #5 on: January 20, 2015, 10:39:04 PM »
 I'd cut my finger and still need a bulb.
Offline jas67
« Reply #6 on: January 21, 2015, 08:44:32 AM »
Cut the original seal beam like some of done for an H4 conversion, and then put one of these in:
http://stores.advmonster.com/h4-led-headlight-rev2/
Classic Honda:
1976 CB400F
1975 CB400F (project)
1975 GL1000
1968 CL175 (1 nice one, one project)
1967 CB77
1967 CB160 (2 of 'em, both projects)
1967 CL160 project
Triumph: 2017 Thruxton R
BMW: 2016 R1200RS, 1975 R90S, 1973 R75/5, 1980 R100S
Ducati: 2013  Monster 796, 2013 848 Evo Corse SE track beast, 1974 750GT, 1970 Mk3d 450, 1966 Monza 250
Moto Morini: 1975 (titled 1976) 3 1/2 Strada, w/ Sport clipons.
Moto Guzzi: 2017 V7III Special,  1977 Le Mans, 1974 Eldorado
