Author Topic: Springs / Retainers for Kenny Harmon D grind.  (Read 3624 times)
Offline Garage_guy_chris
« on: January 15, 2015, 08:26:57 PM »
Hey guys Im finally starting to get the engine build underway and I think Im electing to use a 70/71 stock head I have thats in great condition and barely used after a rebuild. Only problem I have is I would like to run a Kenny Harmon D grind cam and i realize a stock valve train needs some light upgrades to cope.
- Keeping OEM valves and guides so upgrades need to be compatible.
- What is a better upgrade for the springs the kibblewhite springs or APE springs I would prefer to keep the seat pressure and opening pressure to the lower of the two choices ?
       - Kibblewhite is 80# closed 240# @.440" lift  ( im assuming # is pounds?)
       - Cant find specs on APE springs
- Retainers and keepers? Are Titanium retainers required or just a weight reduction thing?
Here are the specs from Satanic Mechanic:
Among others, Kenny Harmon cams were distributed by Action Fours and Megacycle:
        In o/c
        Ex o/c
         Valve   Durat-        btc/abc
Cam      lift    ion       Description                                                      bbc/atc
D        .345    277       A famous grind. Excellent for a major HP        32/65
         .325    294       increase, yet a wide range of use. Long          77/37
                               exhaust duration for sustained high speed
                               cruising without excess combustion chamber
                               temperature. May be used with stock
                              springs if desired.
« Last Edit: January 16, 2015, 10:01:07 AM by Garage_guy_chris »
Offline BPellerine
Re: Springs / Retainers for Kenny Harmon D grind.
« Reply #1 on: January 16, 2015, 10:45:02 AM »
ti retainers are not needed just a weight reduction thing while being stronger than aluminum.even use 77,78 springs a little stronger than the older ones,depends on your budget and how you will use it.bill
1978 CB 750K ard and webers
another anfob
Offline Old Scrambler
« Reply #2 on: January 16, 2015, 12:44:52 PM »
'77 K valve collets and retainers are the same as earlier models...............so will fit your head with the stronger springs. I think '78 K and all 77-78 F models use a different collet so the grove in the valve stem and the retainer shape is different.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Big Jay
    • CBRzone
« Reply #3 on: January 16, 2015, 04:16:37 PM »
Can't believe I have to tell you guys who has the best springs and retainers and valves  for the sohc 750 :P
Offline BPellerine
« Reply #4 on: January 16, 2015, 04:28:04 PM »
sorry big jay,thought he was asking if they were needed not what was best.haha also just saying that the 78 springs are a little stronger.bill
another anfob
« Reply #5 on: January 16, 2015, 04:31:47 PM »
Big Jay maybe you can answer this, as I was gonna email cbrzone.com/sohc.html    tech@aperaceparts.com.
You wouldn't happen to know the closed seat pressure and pressure @ 'X' lift figures on your springs? Also they will work with stock retainers?
« Reply #6 on: January 16, 2015, 05:52:19 PM »
Dennis....77K keepers are different as are the retainers. ;)
« Reply #7 on: January 17, 2015, 07:49:25 AM »
Mike; Thanks for picking me up...... ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #8 on: January 18, 2015, 06:54:44 PM »
 I cheaped out and ran a nice set of stockers until I missed second and bent 2 of my nos valves.  Then I bought APE springs and retainers. I started with a stock F2 cam, I'm running a Kenny Harmon F now.
« Reply #9 on: January 21, 2015, 10:03:32 PM »
Well i got into this further and did some measuring and emailing and now I have some much needed answers:
Stock K spring
@ 1.440 installed height   47.4 lbs seat pressure
@ .345 lift                          145.4 lbs
@ .325 lift                          142.2 lbs
*anybody have there own measurements? im curious how accurate my test rig is...
The Kibblewhite springs. (advertised specs)
@ ? ? ? installed height    80 lbs seat pressure
@ .440 lift                         240 lbs
APE springs
@ 1.440 installed height  95lbs on the seat
@ .345 lift                        215lbs over the nose.
@  .325 lift                       207lbs over the nose.
Mystery springs possibly Manley     < winner winner chicken dinner.
@ 1.440                          60 lbs seat pressure
@ .345 lift                       180 lbs seat pressure
@ .325 lift                       170 lbs seat pressure
* these mystery springs seem like the logical choice a modest upgrade to go with a modest cam. It just so happens its attached to a nice head with stainless retainers and manley SS valves. Im once again changing the plan but whatever.
« Last Edit: January 21, 2015, 10:10:58 PM by Garage_guy_chris »
« Reply #10 on: June 28, 2017, 06:58:47 AM »
Hey guys...bringing this old thread back up.   Currently reassembling my K4 motor after a blow up.
I'm reusing the KH D grind, but cannot find specs on setting the valves.
Guessing it is the same as stock, can anyone confirm?
Thanks
« Reply #11 on: June 28, 2017, 09:34:50 AM »
Std cam valve lash is way too tight.
A hotter cam is usually 0.10mm (0.004") in/ex or little more for ex.
Search for one of my posts where  I have uploaded Action Fours cam data. Kenny Harmon D is among them.
Satanic mechanic website has cam data too
« Last Edit: June 28, 2017, 09:46:44 AM by PeWe »
« Reply #12 on: June 28, 2017, 05:09:22 PM »
I visited SM website, I did not see valve lash specs?
http://satanicmechanic.org/kharmoncam.shtml
What do you suggest?
Thanks
Offline Bill/BentON Racing
    • BentON Racing
« Reply #13 on: June 30, 2017, 04:50:23 AM »
.005 intake and exhaust
BentON Racing Website
BentON Racing Facebook
« Reply #14 on: June 30, 2017, 07:13:38 AM »
