Author Topic: Porting / port cleanup with guides in place?  (Read 1293 times)
Offline Garage_guy_chris
« on: January 15, 2015, 10:05:54 PM »
Just another quick question, is it ok and manageable to do some mild porting / port cleanup with a good set of guides in place and a good valve job already done on the seats? Im not so worried about debris but the guide being in the way?
Offline stikman
  • Bit of an
Re: Porting / port cleanup with guides in place?
« Reply #1 on: January 16, 2015, 01:15:10 AM »
It is if you're careful.  I wouldn't want to touch the seats while porting either before or after they've been done.  But depending on your porting plan, you may want to taper the intakes guides down a bit anyway, so I wouldn't be too concerned about touching those.
1977 CB750A "High Horse": 836cc, mild porting, custom cam, K5 roundtops, v-stacks...
1973 CB750K D5 plunger frame chopper currently building..
Offline Lostboy Steve
« Reply #2 on: January 17, 2015, 08:32:54 AM »
I agree. I ported my head and edged the guides on the intake side a little. Then had a machine shop cut the valves.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline turboguzzi
« Reply #3 on: January 20, 2015, 01:43:21 PM »
doable
