Author Topic: Front Brake Pipe  (Read 1552 times)
Offline hazardus320
Front Brake Pipe
« on: January 18, 2015, 09:28:01 AM »
Hey guys, I have looked around on the web for a little while now and have come up empty handed.  I need to replace my Front brake pipe as I have somehow managed to put a kink in it (I really blame my brother though), it is item #13 in the link below:
http://www.partzilla.com/parts/search/Honda/Motorcycle/1978/CB750A+A/FRONT+BRAKE+CALIPER/parts.html
Does anyone know where I could purchase one?
I did find the pipe for other 750's - I am unsure if it has the same fitment for our A's or not.
http://www.ebay.com/itm/Honda-New-750-Brake-Line-Pipe-450-500-550-CB750K-CB750F-45128-323-020-/330864333421?pt=Motorcycles_Parts_Accessories&hash=item4d090d126d&vxp=mtr
I have found a place where they have the correct fittings, I have emailed them about the possibility of ordering a small order of them:
http://www.brakequip.com/products/automotive-fittings/tube-nuts
Ours is the M10x1.25 Male Tube Nut.
Thanks in advance!
« Last Edit: January 18, 2015, 12:55:44 PM by hazardus320 »
Offline hazardus320
Re: Front Brake Pipe
« Reply #1 on: January 18, 2015, 02:53:49 PM »
Well, as a backup plan (maybe the best solution anyways) I am having my machinist friend make a couple of the bolts tomorrow when he's at work too.
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
« Reply #2 on: January 18, 2015, 03:10:11 PM »
If the fittings are still OK, take them and the old tube to any good auto repair shop. They'll be able to make you a new one and flare the ends using the old fittings. Shouldn't be very expensive.
........Paul
Offline hazardus320
« Reply #3 on: January 19, 2015, 05:26:16 AM »
I would do that, yes, but the one fitting on the caliper side of it is pretty bad.  The line side is good though.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #4 on: January 19, 2015, 06:51:28 AM »
Looks a lot like the caliper pipe on my 78 K, which is still available through Honda. For ten bucks it might be worth a look.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline hazardus320
« Reply #5 on: January 19, 2015, 02:29:20 PM »
Yeah, you're probably right, I should just get one from fleaBay and see if it works for the $10.  I will give that a shot and keep everyone informed of the fit/function.
« Reply #6 on: January 19, 2015, 07:14:39 PM »
Service Honda has the brake pipe for $8.26 (plus shipping) for the 78 CB750K model. Part #45128-323-020. If its too long, a good brake shop could cut and flare to length. If it's too short, at least the flare nuts should be the same and a custom pipe could be fabbed using those ends.
TAMTF...
Wilbur
Projects:
