Author Topic: RE: CB750 Install Grease fitting into front / rear wheel hub  (Read 1482 times)
Offline chewbacca5000
  • I polish covers!
« on: January 19, 2015, 02:07:03 PM »
I have a bike that has sat for 20+ years and I would like regrease the bearings.  Is there a way to regrease, or maybe even install a grease fitting into the hubs?  Bike only has 8,000 miles on it, but pretty sure grease is dried out by now.
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
Re: RE: CB750 Install Grease fitting into front / rear wheel hub
« Reply #1 on: January 19, 2015, 04:13:43 PM »
chewbacca5000,
Has it been kept indoors for that 20+ years????
Reason I ask is that my bike was kept in garage for 26+ years and grease was still grease in the front hub/bearings.
But, I did replace the front bearings, just because.  And will also replace the rear bearings, again, just because.
Charlie
  • I polish covers!
« Reply #2 on: January 19, 2015, 05:15:45 PM »
chewbacca5000,
Charlie
I found it in a shed, but might have spent some time outside.  Recently paid $60 for front and rear bearings at local supply house so not so excited about that.
Wheel work is my least favourite task.
« Reply #3 on: January 19, 2015, 05:21:48 PM »
If you look at how everything is assembled installing a grease fitting that would do any good. Mine probably sat as long and the grease was still grease. I know the white greases turn into something solid, but this is different.
If you find yourself removing the wheels for some reason, I found replacing the wheel bearings pretty easy. Replacing the steering head bearings was a booger. I would burn the sucker before I do steering head again.   ;D ;D ;D ;D ;D ;D ;D
Offline Whaleman
« Reply #4 on: January 19, 2015, 05:24:13 PM »
No real way to install a grease fitting and have it work. Dan
Offline oldhatt45
« Reply #5 on: January 19, 2015, 05:59:38 PM »
chewbacca5000,
LOL, I can understand the "least favorite thing" syndrome.
I know I'm only replacing my wheel bearings because.
And the fact that if they are or have the possibility to go bad after 38+ years, it will happen at the Least favorable time in terms of my health and well being.  LOL
And besides, once every 38 years, I can handle it.  LOL
Charlie
« Reply #6 on: January 19, 2015, 06:21:42 PM »
chewbacca5000,
Charlie
Grease the bearings and put the whole bearing kit in the freezer now so it will always be ready. Make yourself a spanner. Drill out the stakes, be sure to do that. Spin off the retainer. Pound the bearings put from behind. Heat the hub a bit and Tap out the races. When the hub is still warm the frozen races should almost fall into place and only need a few taps to get them in properly. Put the retainer back in, stake it or loctite it and you are ready to roll.
