Author Topic: Spark Plugs - Resistor or Non-Resistor (Canadian Model)  (Read 2060 times)
Offline stikman
  • Bit of an
« on: January 19, 2015, 03:20:15 PM »
I've got a 77 CB750A in Canada.  Wondering if anyone knows why the Canadian Model came with DR8ES-L plugs?  The US models came with non-resistor plugs.  Would they really have changed the plug caps for the Canadian models?  Is there any way to tell if the plug caps are resistor or non-resistor?  What would you recommend running with?
Cheers
« Last Edit: January 19, 2015, 03:23:04 PM by stikman »
1977 CB750A "High Horse": 836cc, mild porting, custom cam, K5 roundtops, v-stacks...
1973 CB750K D5 plunger frame chopper currently building..
Offline stikman
  • Bit of an
Re: Spark Plugs - Resistor or Non-Resistor (Canadian Model)
« Reply #1 on: January 20, 2015, 05:37:17 PM »
Anyone?
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
« Reply #2 on: January 21, 2015, 07:04:13 AM »
I have no idea why the Canadian model would be different than U.S. model, but you can check the plug caps with an ohm meter to check resistance.
...Paul
Offline stikman
  • Bit of an
« Reply #3 on: January 22, 2015, 01:12:21 PM »
Thanks Paul.  Did some resistance testing.  The stock plug caps have about 5 ohms resistance and DR8ES plugs have about 4 ohms resistance.  No reason to run both I guess.  Gonna go with D8EA's.
Offline birdmannn101
  • My Fixerupper 73 CB750K3
« Reply #4 on: January 25, 2015, 04:09:12 AM »
Cheers
Stikman, I always order my plugs direct from NGK.  I see that they have your plug for $2.89
http://www.ngk.com/SearchResults.aspx?kw=DR8ES-L
Dan
CB110
CB160
CB750K
CB750A
S90
CB350Four
CT200
C100
C102
VTX1300
Offline Flyin900
« Reply #5 on: February 12, 2015, 06:08:15 PM »
I think you mean 5K ohms not 5 ohms on the caps and the plugs are usually the same resistance, if they have an R designation. It seems the general thought is there isn't really an issue with the dual resistance from both sources. If you have a chance to use the D8ES or L if available in non resistor, that would be my personal choice. It really is meant for radio interference suppression, so not really needed on these old bikes.
The L designation is for a half a heat range cooler I believe and is between a DR8ES and a DR9ES from what I can see on the NGK site.
« Last Edit: February 12, 2015, 07:53:28 PM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
