Got my calipers put back together with all new parts. Definitely a sequence for the install, which got me thinking about lock wiring. The rules say caliper mount bolts. Is that the 2 socket head cap screws that bolt the two halves together, or the 3 bracket bolts on the fork leg, or all? There isn't much room for doing any of that, especially with the twin caliper setup. I wired up the socket head cap screws off the bike just for practice. Not looking forward to that with the calipers on the bike. Also wondering about the oil reservoir lines. I can see drilling the bolt heads for the fittings at the motor and wiring them together. Do you also have to drill the fittings at the tank and wire them to each other? What do you wire the fork drain plug to, the pinch bolts? Anything on the rear drum have to be wired?
I'm debating what to do about electronics. Dyna 2000, CycleX/C5 optical setup, or that GSXR setup. I'm kind of running out of time, so maybe tackle it after the first race. Is it completely stupid to just throw the old coils (stock) and points back on? I'm not looking to tear up the track first time out, just hoping to make some laps and have fun. With a completely stock motor, are any of those electronic systems very beneficial to me at this point?
Alan
