Author Topic: Tips for reinstalling stock neck bearings?  (Read 398 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: January 21, 2015, 02:12:47 PM »
For reasons I won't go into, I'd like to reuse my stock steering stem bearings. They look okay and the races look fine, and there didn't seem to be any "notches" prior to disassembly.
I've never done it before though - I've always just banged 'em out and installed tapered AllBalls. So what's the proper way to "pack" them? And is there anything else I should know? Seems pretty straight forward....
Offline disco
Re: Tips for reinstalling stock neck bearings?
« Reply #1 on: January 21, 2015, 02:20:39 PM »
Just use plenty of grease on the lower race to hold all the little balls in place. A big dollop of grease on the other side....spread it around a bit & carefully insert tree into frame! Repeat for the top race and you're done.
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
« Reply #2 on: January 21, 2015, 02:27:41 PM »
...and then adjust the top nut as per the factory manual and at the specified intervals
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #3 on: January 21, 2015, 03:01:21 PM »
Thanks guys - I figured as much but wanted to make sure.
Offline Johnie
« Reply #4 on: January 21, 2015, 06:15:50 PM »
I will also recommend to place a white towel under the bike when you lift up the frame to get at those lower ball bearings. They will drop out and are much easier to locate if they do not bounce all over the place. Keep track of how many on top and bottom too.
« Last Edit: January 21, 2015, 06:17:25 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
