Author Topic: 79 GL 1000 el cheapo goldwingo, Sturgis and back at under a grand.  (Read 16922 times)
0 Members and 7 Guests are viewing this topic.
Re: 79 GL 1000 el cheapo goldwingo, Sturgis and back at under a grand.
« Reply #100 on: August 13, 2015, 04:37:24 pm »
 It's awesome you got a set of carbs to use. I hope your seat is better than mine was. I sliced an inch off of the foam before coming home. It's flatter now and not tilted to the tank, my legs catch some of the weight too that helps.
Offline 78 k550
« Reply #101 on: August 15, 2015, 06:21:16 pm »
Leaving tomorrow for Deadwood. Finally got the LTD running good with another forum members carbs. I just need to return them after my vacation.
Paul
Same issue. I got offered to use a bike from the girl next door storing it at parents she lives in Aspen.
So I got to got to our NGW run but on a 09 fatboy.
I'm swapping the rectifer next.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #102 on: March 06, 2017, 02:49:02 pm »
 bump for someone that asked about it.
Offline grcamna2
« Reply #103 on: March 06, 2017, 03:07:27 pm »
Don,
I think I read on your other GW thread on here that you'll be riding that GW to Surgis this yr. 2017' ?
« Reply #104 on: March 06, 2017, 10:53:11 pm »
 That's the pending plan. My brother in law works at the KOA at Mt. Rushmore in the summer. I want to see Devils tower  and may continue west.. There is a Goldwing get together the week after too. If the 79 had a better seat I may have continued on two years ago but the seat ruined me physically for a few days even after I was home. The mufflers were crumbling also.
 I see you are in PA. I was in Chambersburg and Gettysburg late in the fall and W. Virginia a couple weeks ago. Collecting early 750 engines and parts.
« Last Edit: March 06, 2017, 10:54:58 pm by Don R »
Offline grcamna2
« Reply #105 on: March 07, 2017, 02:49:25 am »
I'd much rather be on the road going somewhere than sitting in my little apt. waiting to move..
Don,What type of seat was on the last GW you had that messed-up your trip last time ?
« Reply #106 on: March 07, 2017, 02:41:26 pm »
 I'm not sure, it appeared to be stock shape with a smooth marine vinyl cover but the foam was hard, peaked in the middle and sloped toward the tank. When I got on I had to drop my drawers a little due to the bunching up as I slid forward. The result of the peaked seat was my weight was concentrated on one spot. The result was I almost sang soprano after 15 hours on it. It made the rest of the trip not as fun as it could have been.
 The hacksaw blade foam trim job I did after arriving made it a lot better, going home my legs supported some weight and no more sliding forward. Great bike after that. The PO of the 78 put on a big old cushy seat and wore it out while  the stocker was stored away. I put the stocker back on and like it a lot.
