Author Topic: 79 GL 1000 el cheapo goldwingo, Sturgis and back at under a grand.  (Read 17655 times)
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
Re: 79 GL 1000 it goes, points problem.
« Reply #25 on: February 22, 2015, 05:45:22 PM »
Did you block out the opposite set of points. Place a piece of card in one set of points when your timing the other set.
.......Paul
« Reply #26 on: February 22, 2015, 07:22:25 PM »
Will do, thanks Paul. I never noticed 750's do that, I thought something was wrong. The miss might be old gas. It smelled OK but probably needs a drain out, fill up and some seafoam. When it warms up the miss smooths out. Could be a lean carb, I was hoping to not remove them.
« Reply #27 on: February 22, 2015, 08:50:30 PM »
Check the timing with a strobe, Don. Static timing with a lamp is only for getting it close enough to start. ;)
Offline 6adan
« Reply #28 on: February 22, 2015, 08:54:55 PM »
78 k550, yes that is a six hole made for the 75. That was a good price for the rear Lester. I thank it would be good to change to the 78 front end I thank the brakes are better.
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
« Reply #29 on: February 22, 2015, 09:18:50 PM »
 If we're agreeing the light thing is normal I'll forget it and time it with a strobe. The static is dead on on the first try.
  HA! I noticed it throws oil if you leave the timing plug open and fire it up.
 My brother loaned me a notebook style Honda mechanics 76-79 GL1000 service manual. He got it in the 70's when he worked at a dealership. There's a clymer manual in the folder too, it's coming apart but all the pages are readable. The manual says there's a plastic plug you could get to see the timing marks with it running.
Re: 79 GL 1000 it goes, points problem?
« Reply #30 on: February 22, 2015, 09:21:52 PM »
 My 79 has single piston calipers, I was wondering if there was an upgrade using newer calipers on this front end. I was thinking there was an upgrade swap for 77/78 F 750's using newer calipers maybe there's one for 79 wings too.
« Last Edit: February 22, 2015, 09:23:56 PM by Don R »
Offline MoMo
  • Ride like you're invisible
« Reply #31 on: February 22, 2015, 11:48:24 PM »
That is correct Don about the plastic timing plug.  I still have one and would be willing to let you borrow it if necessary...Larry
Offline 05c50
  • 05c50
« Reply #32 on: February 23, 2015, 05:20:48 AM »
Even with the plug, the oil splashes quite a bit and can make it hard to see, but if you drain 1 quart of oil and set it on the center stand it won't be too bad. Another method is to fit a short length of pvc pipe in the hole to contain some of the splash. Also Randakk makes a nice degree wheel that fits on the left cam pulley that works very well, but it requires you to remove the belt covers.
............Paul
« Reply #33 on: February 23, 2015, 01:52:16 PM »
 I'm an old solid lifter chevy guy so a little oil splash is no big deal. Thanks Larry, that's generous of you. today it's dripping a little antifreeze out the vent hole under the water pump. My brothers bike did that until he started riding it regularly then it stopped. I'm hoping for that kind of luck. The timing wheel sounds cool, I'm going to swap out the timing belts as soon as I'm sure it's a keeper. I might have mentioned the Gates T274 are $12.39 ea. at rock auto.
Offline 05c50
  • 05c50
« Reply #34 on: February 23, 2015, 02:46:26 PM »
It's not unusual for the pumps to seep after waking up from a long sleep. There's a good chance that it will stop after you ride it. That's a good price on the belts, and yes do replace them asap. Broken belts can cause a lot of damage.
.......Paul
Offline 6adan
« Reply #35 on: February 23, 2015, 07:15:58 PM »
Don R, I thank you might be able to use twin piston calipers from a 82 GL1100. I did that on my 79 CBX and it had the same calipers as my 79 GL1000 but am not sure about 78 it has a different part number.
Offline 78 k550
« Reply #36 on: February 24, 2015, 05:28:57 PM »
75-77 will swap with each other
78-79 swap will do the same.
I'm not big on swappping/upgrading. Like the stock approach.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #37 on: February 25, 2015, 11:00:16 AM »
 It seems like the bike tells me if it wants to be stock. My K0 was so heavily part swapped, it became a day 2 restoration. I kept the performance parts but returned the stock cosmetics except the Lester mags and header. My F1 750 told me it wanted to be a triple disc bike, I think the engineers would have liked that. If I think I can upgrade brakes I will, the real world is filled with dumbasses just waiting to pull in front of you.
 The points didn't cure the miss fire on the wing. It's not just skipping that cylinder, it's kicking back like a V8 with a pair of plug wires swapped, except just occasionally. Eventually it will do damage. I'm checking plug wires next to see if there's a wear spot or anything else causing a crossfire. Cam timing is up after that.
Offline 05c50
  • 05c50
Re: 79 GL 1000 it goes, points new, miss still there.
« Reply #38 on: February 25, 2015, 11:50:15 AM »
Have you checked valve clearances yet, it's an easy job on the wings. Maybe you have an intake valve too tight, burnt or bent causing the kick back. Check cylinder leak down after the valves are set.
........Paul
Offline 78 k550
« Reply #39 on: February 25, 2015, 04:41:39 PM »
Your spark advance springs good?
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #40 on: February 25, 2015, 10:47:31 PM »
I plan to check the wires, then the dynamic timing (and advance good call) and lash. I'm draining the gas and starting with alcohol free fresh gas too. Somewhere in there I'll check compression.
 I'm debating on timing belts, it seems like a good enough bike to keep, I may just go ahead and put them on, checking the idlers seems like a good idea.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #41 on: February 27, 2015, 01:16:58 PM »
The belts are pretty easy to change, you don't need to pull the radiator, although that makes it easier. It doesn't cost much money and is a selling point if you decide to sell and something you would do anyway if you keep it.
« Reply #42 on: February 27, 2015, 08:05:49 PM »
If I can cure the miss it's a keeper for sure, If it's something serious it may turn into parts. I'm comitted to getting a chassis job done asap so I haven't been able to spend much time on the wing. I did learn the plug wires are like a 750, made into the coils, that sucks. On the up side GL1200 coils are cheap used, I wonder if they're points compatible.
« Reply #43 on: March 01, 2015, 04:55:10 PM »
 I did split timing according to Randakk's directions and rechecked it, timing is good, too much oil for a running check, I need to drain some out, the misfire still is there,  cranking compression was 100 on 3 cylinders 75 on 2 and it seemed to be chugging on #2 but a leak down test looked like just a few % leak. I did back off the intake valve just because the motor kept rotating due to the air. The top right motor mount/ crash bar bolt was gone. The other side was loose. hmmmm.
Offline 05c50
  • 05c50
« Reply #44 on: March 01, 2015, 05:26:11 PM »
Those compression readings are pretty low, but I've seen the compression on these come up quite a bit after putting some miles on it. If it's been sitting a few years, there's a good chance the rings are sticking. Is it running enough to ride around a little bit?
.......Paul
« Reply #45 on: March 01, 2015, 06:27:05 PM »
 I used a huge tester, I suspect the long hose cut down the numbers a little, the low #2 and the chugging sound concerned me the most. The missfire feels like it could do damage, it doesn't just drop the cylinder, it kicks back. I only did what I had time for today, I'll run the valve lash tomorrow and try it again. I have an on engine valve spring checker, I'll see if it fits and check the valve travel and see if something is hanging up. now that the crash bars are off I can check the timing belts and idler too.
 The plugs are black from the choke, I tried to start it outside yesterday at 20 degrees F. No deal. Inside it fires right up.
The streets are snow covered here, no chance of me riding it any time soon.
« Last Edit: March 01, 2015, 06:29:14 PM by Don R »
Re: 79 GL 1000 it goes, points new, miss fixed!
« Reply #46 on: March 02, 2015, 08:41:42 PM »
   Actually the offending cyl. was #1. I  adjusted the valves, there was almost no valve lash, I ran out the gas, refilled with fresh no alcohol premium and a little lucas injector cleaner. It started, missed once, then a little one and hasn't done it since. I let it cycle the fan a couple times. Now I can go back to fixing the brakes and making it pretty again. I have the crash bars off so I may as well order the timing belts now. I'm thinking someone adjusted the valves incorrectly and #1 was hanging open a little. It may have had some carbon on the valve seat.  I'm thinking it wants me to take it to bike week.
Offline 05c50
  • 05c50
« Reply #47 on: March 03, 2015, 05:43:48 AM »
Good for you. Sometimes all it takes to get them running right is to undo the previous owners "repairs".
............Paul
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #48 on: March 03, 2015, 06:54:55 AM »
I concur!  8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Bankerdanny
« Reply #49 on: March 03, 2015, 06:57:15 AM »
You don't need to order the belts, you can buy them at any auto parts store.
The tech section at the NGW forum has the part numbers.
