Author Topic: cb750 oval link cam chain w/ stock tensioners?  (Read 1696 times)
Offline Garage_guy_chris
« on: January 26, 2015, 10:31:26 pm »
Hello. I have a quick question about cam chains. I want to run an oval link BF05M x 94L. I just wanted to confirm that these will work ok with the stock tensioner, guide wheel and guide? Im 98% sure it will but just wanted to make sure before i order parts.
Re: cb750 oval link cam chain w/ stock tensioners?
« Reply #1 on: January 27, 2015, 07:20:05 am »
If anything it is better than the OEM peanut type chain
Offline Big Jay
    • CBRzone
« Reply #2 on: January 30, 2015, 10:56:08 pm »
Oval chains are designed to be used with straight style guides only, On models like the CB750 and the KZ Kawasakis that the chain goes around a round sprockets, should use peanut style
Online PeWe
« Reply #3 on: January 31, 2015, 03:35:36 am »
I have a heavy duty TSUBAKI BF05M-94 (Camellia)  with OEM tensioner. Std chain is not good enough with hotter cam and harder springs, right?
Any problem with that? I did not get any problem with that, except hardening rubber wheel and small pieces of it in oil pan
- Better alternative is this?
http://www.m3racing.com/graphics/parts/CamCntrl750Honda.jpg
OEM primary chain tensioner with Heavy Duty primary chains from  ClassicCycleCity too.
« Last Edit: January 31, 2015, 03:43:48 am by PeWe »
