Author Topic: Muffler for 4into1 - 2.5" OD  (Read 13528 times)
Offline RebelYankee
« on: January 30, 2015, 07:16:06 AM »
Hey guys,
I have a 4into1 with a OD of 2.5".  Any ideas what muffler would fit this?  It is from my 82 CB650 parts bike.
Thanks,
Jamie
1980 CB650C
Re: Muffler for 4into1 - 2.5" OD
« Reply #1 on: January 30, 2015, 07:18:50 AM »
Cone engineering makes 2 slipons with 2.5"ID
a 12" open reverse cone, and an 18" Quiet core.  Both are of excellent quality.
coneengineering.com
« Reply #2 on: January 30, 2015, 07:19:43 AM »
For instance this one from DCC:
http://www.dimecitycycles.com/12-inch-stainless-steel-shorty-universal-cone-muffler-for-2-1-2-inch-exhaust-pipes.html
Edit:  it is the same as flybox posted, just different seller.
« Reply #4 on: January 30, 2015, 07:26:32 AM »
Me too :)
Bought a dimpled one for $20 less from the dime section:
http://www.dimecitycycles.com/dime-store-discount-motorcycle-parts-and-gear.html
Offline RebelYankee
« Reply #5 on: January 30, 2015, 07:36:57 AM »
Sweet!  Thanks for the replies!
1980 CB650C
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #6 on: January 30, 2015, 07:53:03 AM »
Another vote for Cone Engineering. I purchased mine directly from them. Great people to deal with on the phone.
--Evan
1975 CB750K "Rhonda"
Offline Killer Canary
  • Typical Bran Muffin
« Reply #7 on: January 30, 2015, 03:10:38 PM »
Build your own. Then you can make it whatever size you please.
Kawi GPz900, H1
Offline Chachi
« Reply #8 on: January 31, 2015, 07:28:17 PM »
I've been debating both of those cone mufflers. Can anyone enlighten me on the pros/cons of each? 12" open vs. 18" quiet core. I currently have an old mac slip on (most likely, not 100%) on a 750 k3 with 4-1. It runs well with these specs: 657b carbs, 110 main, 40 idle, needle clip 4th from top, float 26mm, air screw 1 turn out. Would rejetting be needed for either of the two cone mufflers?
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #9 on: January 31, 2015, 07:34:14 PM »
It would be partly based on your tollerance for loud pipes. The 12" open is very loud, but oh so good. Very free flowing compared to the Quiet Core. There is a good chance you will need to tweak the jetting with either of these mufflers.
Offline DaveBarbier
« Reply #10 on: January 31, 2015, 08:47:14 PM »
I have the quiet core from DCC and it's not too loud. I never want a loud bike so I was a little nervous when I started it up. It is slightly louder than the stock 4-4 on my 550. I did have to rejet but mainly because I moved to pods and now to velocity stacks.
1978 Honda CB550K
Offline Djfob
« Reply #11 on: January 31, 2015, 10:27:40 PM »
I've ran both, the 12" shorty is just too loud for my likings. You'd need to rejet for it,  queitcore it runs like a top on stock jet sizes.
I have a stock air box
78 CB750k
Offline evanphi
  • Apparently I'm an
« Reply #12 on: February 01, 2015, 10:57:32 AM »
Ditto on the no need for rejetting with the 18" and stock airbox.
I love the sound of mine!
--Evan
Offline maduncle
  • Don't confuse me with a
« Reply #13 on: February 01, 2015, 01:47:46 PM »
I just fitted a Lossa Engineering reverse cone stainless steel shorty muffler with a 2" inlet onto my 4 into 1 collector which had a 2 1/2" outlet.
I needed about 4 inches of pipe between the two so I got an adaptor made up at the local exhaust joint.
Lossa sell the same muffler with a 2 1/2" inlet, I believe it is a Cone Engineering muffler with a Lossa badge.
Sounds good, looks good, got some tuning to do ...
CB750K2 (only slightly modified)
Offline Chachi
« Reply #14 on: February 01, 2015, 08:27:43 PM »
So is the consensus that I would probably have to rejet for the 12" open shorty, but not the 18" quiet core? Also, anyone have any pics of which bracket you used on the muffler and how you mounted, etc.?
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #15 on: February 01, 2015, 09:49:02 PM »
Cone Engineering sells weld on mounting tabs.
They work great for hanger brackets.
Offline evanphi
  • Apparently I'm an
« Reply #16 on: February 02, 2015, 06:47:23 AM »
Yep. Get the bracket from CE.
Mine is the three-sided one that looks like the one on the MAC. It hangs from a strap on the passenger footpeg.
« Last Edit: February 02, 2015, 06:52:25 AM by evanphi »
--Evan
Offline Chachi
« Reply #17 on: February 02, 2015, 09:32:42 AM »
Can you send a pic of the backside where the bracket is?
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline evanphi
  • Apparently I'm an
« Reply #18 on: February 02, 2015, 05:54:03 PM »
Parts List: http://www.coneeng.com/pdf/motorcycle/Collector%20Components%20PDF.pdf
And here it is mocked in place on mine. I just rotated the extension to get it in line with the hanging strap, which is now vertical and cut to length. I also put the center stand stop on the other side.
« Last Edit: February 02, 2015, 06:07:37 PM by evanphi »
--Evan
Offline Chachi
« Reply #19 on: February 03, 2015, 07:04:45 AM »
Thanks for the pics. Would the center stand stop not work/fit with that bracket in that location?
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
« Reply #20 on: February 03, 2015, 08:29:32 AM »
with stock exhaust gone, the center stand will contact the chain.
I hung a center stand stop off my L-side passenger peg.
Here's how my exhaust was mounted.
Offline Chachi
« Reply #21 on: February 03, 2015, 08:47:40 AM »
But will the stand stop work on the right? Mine is on the right with my current Mac slip on which has similar bracket mount as flybox. I have a hanger strap which connects muffler bracket to bolt through right passenger peg mounting hole which also holds stand stop. All on right. I guess if the stand stop works just as well on the left it doesn't matter what side, right?
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
« Reply #22 on: February 03, 2015, 08:51:15 AM »
It does not matter as long as its not resting on the chain.
Offline stewonepot
« Reply #23 on: February 03, 2015, 09:31:18 AM »
I had the same problem ,but it dosnt matter which side you do it ! just for looks
Regards Stew
ps pass pegs are strong
Offline evanphi
  • Apparently I'm an
« Reply #24 on: February 04, 2015, 04:51:47 AM »
Yep doesn't matter which side it was on... I just didn't want both on the same peg for looks.
--Evan
