Author Topic: Best way to strip the paint off these mag wheels *Hayashi Wheels*  (Read 3597 times)
Offline rocs
I am hoping to find some good tips or trick on cleaning up these Hayashi wheels. The previous owner painted them white. Since they, they began peeling and have some bubbles in some locations.
Whats the best way to strip the end clean them up? What are my options?
Thanks!
1975 CB550k's
Offline calj737
  • I refuse...
Re: Best way to strip the paint off these mag wheels *Hayashi Wheels*
« Reply #1 on: January 30, 2015, 03:36:35 PM »
Acetone and a red ScotchBrite.
Offline rocs
« Reply #2 on: January 30, 2015, 03:40:27 PM »
Thanks! gonna get started on them tomorrow
1975 CB550k's
« Reply #3 on: January 30, 2015, 05:01:18 PM »
You may want to use Brake fluid. It does eat paint as we all know.
Offline wowbagger
  • Not much of an
« Reply #4 on: January 30, 2015, 05:09:39 PM »
Aircraft remover takes everything off and fast. Most auto shops in the states carry it.
Offline socal1200r
« Reply #5 on: January 30, 2015, 05:10:32 PM »
Easy Off foamy oven cleaner, gloves, and 000 steel wool...
Offline rocs
« Reply #6 on: January 30, 2015, 05:13:52 PM »
Thanks. I actually have this at home. Will try it
1975 CB550k's
Offline wowbagger
  • Not much of an
« Reply #7 on: January 30, 2015, 05:26:38 PM »
I'd recommend wearing double latex gloves or some heavy duty chemical gloves. That stuff burns like mad if you get it on your skin.
« Reply #8 on: January 30, 2015, 05:30:44 PM »
Yeah, and eye protection!!!! :o
Offline calj737
  • I refuse...
« Reply #9 on: January 30, 2015, 06:17:00 PM »
Which is why I recommended Acetone. Lots of things work, lots. Acetone is easy, evaporates quickly, and won't kill you. But the Aircraft Stripper works great. It may also remove the factory protective finish though, so if you're at all concerned about that, proceed carefully.
Offline chewbacca5000
  • I polish covers!
« Reply #10 on: January 30, 2015, 06:20:46 PM »
Man those are awful better send them to me, and save yourself the trouble.
Offline rocs
« Reply #11 on: January 30, 2015, 07:17:49 PM »
Ok, doing Acetone first for these reasons..
1975 CB550k's
Online seanbarney41
« Reply #12 on: January 30, 2015, 07:28:01 PM »
WARNING!  I think those are anodized underneath that crappy paint!  (unless the po sanded it off or something already)  DO NOT USE OVEN CLEANER! and i probably would not use paint stripper either.  However, you may find that the Gold/Bronze colored anodizing is already ruined and then you might as well have at 'em with whatever works.  Start small on the most inconspicuous place you can find....try Laquer Thinner too or maybe an epoxy paint reducer, wear respirator and gloves.
Offline Brantley
  • Drano
« Reply #13 on: January 30, 2015, 10:26:29 PM »
Aluminum and steel don't really like each other. Stay away from steel wool as it can imbed itself into aluminum and rust.
Use Scotch Brite. Old or used dot 3 brake fluid is a great rattle can paint remover, and won't (much) harm the anodization beneath the paint if you work quickly (if they are anodized). Aircraft stripper is another good option, if you don't mind super nasty chemicals (wear big yellow kitchen gloves). Either way, scrub the bejeezus out of them with yr favorite dish detergent after. You didn't mention what direction yr going; the powder coater I use will bead blast small parts (I mean smaller than a frame) as part of his fee. Maybe there's one near you? Or, once the paint's gone, you can spend a bunch of hours with hot water, detergent, varying grits of sandpaper and Scotch Brite, followed with Simichrome (which ain't cheap but is an excellent polish/ sealant) for a factory Honda kinda look. If you want to repaint them start with a self etching primer after you get 'em clean.
« Reply #14 on: January 31, 2015, 06:35:08 AM »
I suggested cheap Brake Fluid since you don't need a Hazmat suit and it really only really eats paint. It will not stink up the house if you are working inside an attached Garage or workshop.
Offline 78whiteorbs
« Reply #15 on: January 31, 2015, 06:38:03 AM »
[quo author=rocs link=topic=144635.msg1646212#msg1646212 date=1422674269]
[/quote]
+1 lacquer thinner.
Problem with brake fluid is its very hard to remove all of it if you are going to paint them again or whatever.
« Last Edit: January 31, 2015, 06:39:41 AM by 78whiteorbs »
« Reply #16 on: January 31, 2015, 06:47:36 AM »
Lacquer thinner is super flammable since it uses some of the same chemicals as nitroglycerine in production, and it really out gasses explosive fumes. If the coating underneath is shot he is going to have to prep the surface and polish or etch anyway.
Online seanbarney41
« Reply #17 on: January 31, 2015, 12:06:19 PM »
Bobby, brake fluid goes right through your skin to cause liver damage.  It is really nasty stuff.
Offline slikwilli420
  • Master of Disaster
« Reply #18 on: January 31, 2015, 03:03:34 PM »
So does acetone.
Offline Lostboy Steve
« Reply #19 on: January 31, 2015, 05:20:44 PM »
Well, then I'm #$%*ed. I've even gotten it in my eye before.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #20 on: January 31, 2015, 05:41:31 PM »
Sometimes well meaning misinformation is passed along. Here is an excerpt form the MSDS sheet.
Product/Chemical Name: DOT 3 BRAKE FLUID
Acute Effects
Inhalation:
Vapors are mildly to markedly irritating to the lungs depending on the exposure level.
Eye:
Causes severe irritation experienced as discomfort or pain,
excess blinking and tear production, with marked excess redness and swelling of the conjunctiva.
Skin:
No adverse effects expected with exposure to skin. Brief contact may cause slight irritation.
Prolonged contact, as with clothing wetted with material, may cause more severe irritation and
discomfort, seen as local redness and swelling.
Ingestion:
Ingestion may be fatal. May cause abdominal discomfort, nausea, and vomiting. May
produce central nervous system depression and kidney damage.
Carcinogenicity:
This compound contains no ingredients at concentration of 0.1% or greater that
are carcinogens or suspect carcinogens.
Medical Conditions Aggravated by Long-Term Exposure:
Pre-existing skin, eye, and respiratory disorders may be aggravated by exposure to this
product. Impaired kidney function from pre-existing disorders may be aggravated
by exposure to this product.
Chronic Effects:
Repeated exposure may result in drying of the skin and mucous membranes,causing irritation and dryness.
Section 4 - First Aid Measures
Inhalation:
Remove to fresh air. If not breathing, give artificial respiration. If breathing is difficult,
give oxygen. Call a physician.
Eye Contact:
Immediately flush eyes
with plenty of water for at least 15 minutes, lifting lower and
upper eyelids occasionally. Get medical attention immediately.
Skin Contact:
Remove any contaminated clothing. Wash skin with soap and water for at least 15
minutes. Get medical attention if irritation develops or persists. Wash clothing before reuse.
Ingestion:
Do not induce vomiting. Never give anything by mouth to an unconscious person.
Acetone on the other hand:
Primary Routes of Exposure
Inhalation, ingestion, skin, and eye contact.
HAZARD CLASSIFICATION
Acute Effects
Central nervous system depression is the most common effect, resembling intoxication by ethyl alcohol. Excitation is followed by impaired motor coordination, slurred speech, sensory
disturbances such as double vision and vertigo, flushing of the face, rapid pulse, and sweating. Nausea and vomiting are common. Other symptoms include dryness of the mouth and
throat, headache, sleepiness, dizziness, light-headedness, weakness, and loss of energy. Very high exposures may cause unconsciousness, coma, or death. Kidney toxicity may occur but
is rare following acute exposure. Post-alcoholic headache and gastritis are common in recovery. Inhalation exposure may cause lung irritation and cough. Skin contact may result in redness, irritation, and dermatitis since acetone has a drying effect on the skin. Contact with eyes can result in irritation and eye injury.
Chronic Effects
Irritation of the eyes, nose, and throat are the most common problems associated with chronic exposure to acetone. Central nervous system effects such as dizziness and sleepiness can occu
r, as can dryness, irritation, and inflammation of the skin.
Carcinogenic
Acetone is not considered carcinogenic by OSHA, NIOSH, NTP, IARC or EPA.
Potential Adverse Chemical Interactions Acetone may increase the toxicity to the liver and kidney of chemicals such as ethanol, 1, 2-dichloroethylene, and chloroform.
Humans with liver or kidney disease may be at increased risk due to this potentiation effect
Some of the chemicals we have used in our lives were quite dangerous.
Offline 78whiteorbs
« Reply #21 on: January 31, 2015, 05:45:23 PM »
Both are better than MEK
Or methylethyl death as Iit.I once heard it called.
Few other chemicals available to the masses freak me out like that stuff does. I wear gloves google and the whole nine when I have to use that stuff. I actually hate having it around.
Online seanbarney41
« Reply #22 on: January 31, 2015, 06:36:53 PM »
hmmm...thanks Bobby, consider me educated :)
« Reply #23 on: January 31, 2015, 06:57:16 PM »
No thanks needed. I just got used to looking as part of my work. I got some real surprises.
