Author Topic: Are there any quick release fastener options for side covers?  (Read 629 times)
Offline Juan1
« on: January 31, 2015, 05:32:12 PM »
Are there any quick release fasteners I can put on my side covers so I can have easy access to the fuse box and dipstick?
Re: Are there any quick release fastener options for side covers?
« Reply #1 on: January 31, 2015, 06:07:44 PM »
If they are tight, which is common. You can grease the tabs and o rings which make them much easier to remove. If you have some of the aftermarket that screw on you could get a different fastener.
Offline Old Scrambler
« Reply #2 on: February 01, 2015, 10:05:14 AM »
Lubricate...........Yes...........but a petroleum-based grease or oil will eventually shrink the grommets and cause the side-covers to 'fly' away >:( >:( >:(
A little graphite may be better. :) :) :)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #3 on: February 01, 2015, 12:18:49 PM »
Order some new rubber grommets too. Makes a big difference and won't cost you much.
Offline RevDoc
« Reply #4 on: February 01, 2015, 02:51:48 PM »
As Old Scrambler is right on the mark! Having dealt with many o-rings and rubber gaskets in my years doing industrial elec. work I found that a silicone type lube is best. If you have access to Lowes's or Home Depot type DIY stores they usually stock them.
Dana
'78 CB550K--Angie
'82 CB750 Custom--Eva
As soon as you straddle a bike expect every other driver on the road to suddenly start competeing for the title "Dumbestsonofa#$%*inallNorthAmerica!!"
