Author Topic: Float bowl drain bolt o-ring  (Read 735 times)
Offline BruceG
« on: February 01, 2015, 09:46:05 AM »
While cleaning out all the carb jets, I discovered that two of the o-rings on the float bowl drain banjo bolt had split in two.  Not wanting to buy a whole carb kit just for these o-rings, I made some measurements and determined that I needed a 5mm ID and 8mm OD ring.  First I went to several hardware stores who had only plumbing o-rings which would not last long in that environment.  And auto parts places had o-rings but not in the size I needed.  I called two local rubber/gasket in-trade houses who dealt in the SAE equivalent sized o-rings in Viton but they had a minimum order: one was $30 and the other was $100.
Off to McMaster-Carr I went and found just what I needed in Viton at $4/25 (http://www.mcmaster.com/#o-rings/=vq01u7).  They fit perfectly and when the gas tap was turned on, nary a leak was found!  And a quick ride around the block also revealed that my carb jet cleaning went well for full power was restored.
Since I don't have a fleet of SOHC4's to use the remaining 21 o-rings, I'm offering them at low low price of $.20 each + postage ($.50 US, international a bit over $1).  Contact me directly if want to purchase a few.
Bruce
Bruce Giller, Esq.
SOHC/4 #2
'76 CB70F
'72 Moto Guzzi Eldorado
'73 Alfa Romeo GTV
