Author Topic: Kickstarter joint - stuck...  (Read 710 times)
Offline cb400f/20yo/semi-broke.
« on: February 03, 2015, 01:34:21 PM »
My joint was cracked when i bought the bike, and during the winter I've decided to fix it.
But apparently the joint won't come off, so I am wondering if I have missed something?
I've considered using a puller (picture uploaded below).
It's a CB400F.
Best Regards.
« Last Edit: February 03, 2015, 01:38:13 PM by cb400f/20yo/semi-broke. »
Offline DaveBarbier
Re: Kickstarter joint - stuck...
« Reply #1 on: February 03, 2015, 01:59:25 PM »
You obviously removed the bolt that clamps onto the splines, right? I don't see it in the pic so I think you're good, but it has to be removed completely, loose won't do it. Sometimes there just a lot of grit in the splines so you have to work on it. Or use a screwdriver to carefully open the split a bit.
If it's rusted or something maybe a penetrant would help? PB Blaster?
1978 Honda CB550K
« Reply #2 on: February 03, 2015, 02:40:16 PM »
I'll try some more wiggling, more than i have already done....  >:(
And yes, the bolt is removed and everything else. As far as i can tell, the puller is kind of a last resort thing.
Appreciate the replies!
Best Regards :)
« Reply #3 on: February 03, 2015, 02:49:16 PM »
Usually a screwdriver driven in the slot a little to expand the joint works well for slotted deals like kickers, brake pedals, turn signals etc..
Offline DaveBarbier
« Reply #4 on: February 03, 2015, 04:28:01 PM »
Best Regards :)
Yeah, last resort. If the splines are not lined up and are ruined by using the puller it will be equally as hard to get it back on.
1978 Honda CB550K
Offline Thousandson
  • Ride, Fix, Repeat
« Reply #5 on: February 03, 2015, 05:21:53 PM »
Hit it in and out. A little motion both ways, and some lube.
Current ride: 78' Cb750F
Nic
« Reply #6 on: February 03, 2015, 08:26:59 PM »
This would be my first choice, usually nothing more is needed. Whack the screwdriver into the gap, leave it there and wiggle the thing off with the screwdriver still wedged in the slot, shouldn't need more than that.
