Author Topic: Stripped Header Stud  (Read 2393 times)
Offline maconnoise
« on: February 04, 2015, 06:15:34 AM »
When I replaced the headers on my 78 CB750k a few days ago I discovered that a PO had stripped the threading out of one of the stud holes in the cylinder head. Right now the stud barely stays put and just rotates if you put more than a few pounds of torque on the header bolt. I looked into the hole and nearly all of the threads are gone.
What are the possible fixes for this? I am no master mechanic and I don't plan on pulling the engine any time soon so getting a machine shop involved is a worst case scenario at this point. Not particularly jazzed about drilling and tapping either.
I guess JB Weld is a bad idea  ::)
78' CB750k
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Stripped Header Stud
« Reply #1 on: February 04, 2015, 07:34:36 AM »
Very bad.  :(
Helicoils are fairly straightforward, the hardest part is keeping it square and true since the header studs are at odd angles.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline maconnoise
« Reply #2 on: February 04, 2015, 10:00:20 AM »
Yeah looks like Helicoils are going to be the best bet. I'm just never excited to go drilling holes into my engine. Call me crazy.
Thanks for the info. This is my first real project bike and I am still a bit unsure of my abilities. It's been a long time since I spent any real time in a shop.
78' CB750k
« Reply #3 on: February 04, 2015, 10:11:03 AM »
find someone who can do it for you.
it needs to be done right, the first time.  search the SERVICES section of CL for mobile auto repair.
IIWM, i'd leave the opposing stud in, and slide the exhaust collar on it to be used as a drill guide, or to familiarize myself with the angle the stud needs to be placed.
« Reply #4 on: February 04, 2015, 06:31:52 PM »
That is a heck of an idea, I had not considered that  :o ! I have yet to repair the threads for an exhaust stud, but it's only a matter of time  :'( . Rest assured I will use the collar as a guide when that time comes.  8)
TAMTF...
Wilbur
Projects:
Offline Flyin900
« Reply #5 on: February 04, 2015, 08:37:27 PM »
If you have the hole there already then I would use only hand tools and nothing power operated to hand tap a larger thread for the insert.
Never been a fan of Heli Coils and prefer Time Serts for a much better and stronger repair, yet the tools/taps are not cheap to buy for a one time repair. There are also Big Serts if the hole is really messed up.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
« Reply #6 on: February 05, 2015, 07:47:58 AM »
Very bad.  :(
Agreed
« Reply #7 on: February 05, 2015, 01:12:39 PM »
Make a thick guide to ensure correct angle when doing the threads for helicoil. It can be fastened with the ok bolt.
It's very easy to aim the helicoil thread tap wrong and stud will not fit correctly.
Offline Davidov
  • 1978 CB750 F3
    • My CB750F project log
« Reply #8 on: February 06, 2015, 02:14:09 PM »
Yes. You should get one of those tap handles  for the drill bit and drill out the hole by hand. It's just aluminum.
-David
Offline Dino
    • HackAWeek
« Reply #9 on: February 06, 2015, 02:44:25 PM »
I like E-Z Lok inserts best. They use standard thread taps and drill sizes and they install with a flat blade screw driver. Each insert is coated with thread lock. I love these and swear by them. I've installed dozens over the years. http://www.ezlok.com/InsertsMetal/carbonSteel.html
If it ain't broke, don't fix it!
Offline 750cafe
« Reply #10 on: February 06, 2015, 05:47:18 PM »
These might help...
Eric
Is there anything more fun than riding? They are between your legs and are quiet when you turn them off.
