Author Topic: Greetings from Florida!  (Read 1272 times)
Offline newcastleadam
« on: February 06, 2015, 04:35:21 AM »
Good morning everyone!
New member here posting up!  Been in motorcycles for quite awhile now, and picked up my first SOHC.  Pictured below is my new-to-me 1978 CB750F Super Sport.
Got it cooking on 3/4 cylinders with starting fluid, digging into the carbs now.
Adam
Re: Greetings from Florida!
« Reply #1 on: February 06, 2015, 04:49:30 AM »
Welcome!
« Reply #2 on: February 06, 2015, 04:56:33 AM »
Welcome from Texas.  Should be minor getting that fourth kettle cookin...
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: February 06, 2015, 05:34:12 AM »
Welcome aboard! You might want to start planning to attend the Manufacturer's Cup drag races in Valdosta in April:
http://www.manufacturerscup.info/?cat=37
We have a strong contingent of members here that attend (and even race) at this event. Excellent track, and even better company! From Gainesville you could drive up for just one day at least, just look for all the SOHC/4's.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #4 on: February 06, 2015, 06:12:06 AM »
Thanks all.  The bike had been "worked" on by a "shop"; they totally took the PO for a ride, poor bastard never even got to ride it.  Now repairing the "work".  For instance, bike came with 1 throttle cable, choke was upside down and backwards and twisted on, and it has a HD Sportster exhaust.  Might be a few more surprises :-)
Offline calj737
  • I refuse...
« Reply #5 on: February 06, 2015, 06:23:27 AM »
Oh dear God! Better check to make sure any and all fasteners that may have been removed (cover bolts etc) are indeed metric and not SAE...
« Reply #6 on: February 06, 2015, 06:26:04 AM »
Here's a taste.
« Reply #7 on: February 06, 2015, 06:26:27 AM »
P.O.'s (previous owners) are bad enough, but when I see what some of these mouth breather's that call themselves "professional" mechanics can botch and hack mechanically, really makes me wonder. I'm currently whipping a 1997 Suburban into reliable condition that happens to be one of the most mechanically neglected machines I've ever come across...
and that's compared to a 1978 F250 crew cab that I had that was being used as a dumpster when I got it!
TAMTF...
Wilbur
Projects:
« Reply #8 on: February 06, 2015, 06:29:40 AM »
Here's a taste.
Wow...
just freaking wow.
You got me beat... my current project only had four different types of screws in the carb bowls. Looks like you've got at least six different types of screws! I have gotten pretty good at Helicoil repairs of the bowls screws though.
TAMTF...
Wilbur
Projects:
Offline calj737
  • I refuse...
« Reply #9 on: February 06, 2015, 06:31:11 AM »
How much do you think they drilled the jets in those carbs to make them run better?
« Reply #10 on: February 06, 2015, 06:35:02 AM »
After seeing the outside I was...apprehensive.  But it looks like the shop just did a carb clean and replaced the bowl gasket.  But since cylinder #1 isn't running need to make sure I double-check that carb.
Offline calj737
  • I refuse...
« Reply #11 on: February 06, 2015, 07:05:47 AM »
If that model of carb allows the removal of the emulsion tubes and jets without breaking anything, I'd pull them apart and carefully inspect them for stock Honda brass, and verify that the jets haven't been drilled. Just worked on a set with a member who's stock 38 slow jets were drilled to about 60s. No wonder the bike fouled plugs after idling 3'...
« Reply #12 on: February 06, 2015, 07:33:58 AM »
They're pulled and look unmolested.  Thankfully.
