Author Topic: CR750 Steering damper brackets.  (Read 2912 times)
Offline Jadahonda
« on: February 06, 2015, 07:37:10 pm »
Is there someone who have a photo of the original brackets for the steering damper and the 2 stopper for steering angle here? I need some photo's for making repro's
Part number Steering damper brackets: 53710-300-970 and 53720-300-970
Part number Steering angle stopper: 50200-300-970 and 50201-300-970
Jan
1958 Honda C70 Dream
1959 Honda C92 Benly
1960 Honda CS92 Ongoing Project
1960 Honda CB92 Benly
1960 Honda CB92 Racer
1961 Honda CB72 Racer
1962 Honda CS92
1963 Honda CB77 Ongoing Project
1967 Honda CB450 Black Bomber
1968 Honda Z50A
1969 Honda CB750 K0
1969 Honda CB750 Sandcast
1969 Honda CR750-Ongoing Project
1970 Honda CB750 Police
1970 Honda CB100
1970 Honda CL100
1970 Honda SL100
1971 Honda CB500
1975 Honda GL1000
1975 Honda CB400F Supersport
1979 Honda CBX 1000, serial number 52
1981 Honda CBX 1000 ProLink
1989 Honda VFR400R (NC30)
Offline Old Scrambler
Re: CR750 Steering damper brackets.
« Reply #1 on: February 07, 2015, 07:23:54 am »
I took these fuzzy pics of the Mark McGrew bike at the Barber Museum.  Contact Mark at M3Racing.  The dampener and several of the clutch-perch and cable adjuster parts are 'borrowed' from the CL72 and early CL77 models.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline napoleonb
« Reply #2 on: February 07, 2015, 02:38:03 pm »
Perhaps these pics help a bit, don't know where i've found them.
I'v got 2 CL72 steering dampers and you can open them up for restoration.
The Dick Mann type of racing bike didn't use these brackets, they were weld directly onto the lower triple tree and frame.
Offline napoleonb
« Reply #3 on: February 07, 2015, 03:05:19 pm »
I quickly made a 3D part of it, figuring it should look quite similar and would have been a single stage press stamping part.
Just eyeballed the main dimensions from a few blurry pictures off course.
Edit1: The upper picture is from Yoep Kortekaas his bike, its a true CR750 kit bike with almost all of the original parts.
Edit2: The second picture is from Paul McGhie his bike, also a true CR750 kit bike with almost all of the original parts, redid my drawings to match a little better.
« Last Edit: February 07, 2015, 03:47:59 pm by napoleonb »
Offline Jadahonda
« Reply #4 on: February 07, 2015, 09:21:19 pm »
The last two CAD drawings was very good. The photo of the CL77 vs CR750 steering damper is from me...
If someone now have a good photo of the rear bracket it would be fine. The best photo I have is this.
1962 Honda CS92
1968 Honda Z50A
1969 Honda CB750 K0
1970 Honda CB100
1970 Honda CL100
1970 Honda SL100
1971 Honda CB500
1975 Honda GL1000
Offline napoleonb
« Reply #5 on: February 21, 2015, 09:51:03 am »
@Jadahonda do you have the Original CR750 steering damper of did you take the pics? I would really like to redo/remake my CL77 steering damper outer shell to CR specs but lack the measurements.
Offline Jadahonda
« Reply #6 on: February 21, 2015, 11:30:57 am »
Yes. the steering damper I have is an original. I will come back here With details.
I still miss some good photo's og the rear bracket if anyone have....
Jan T.
1962 Honda CS92
1968 Honda Z50A
1969 Honda CB750 K0
1970 Honda CB100
1970 Honda CL100
1970 Honda SL100
1971 Honda CB500
1975 Honda GL1000
Offline napoleonb
« Reply #7 on: February 21, 2015, 12:51:57 pm »
I hope this helps, these are the best i could find but i dont know which are original tough.
The pics from the naked frame are from M3 racing (DSFC), i doubt this is the original bracket as this differs from the other pictures but cant tell for sure.
screenshot003 is from Yoep's bike
Offline kmb69
« Reply #8 on: February 21, 2015, 01:52:49 pm »
I bought that M3 chassis or at least one he built just like it.
It is the basis for one of the two CR's I am building.
The second one is based on frame #7 of only 7 CR Spondon frames that were built.
« Reply #9 on: February 22, 2015, 02:17:09 pm »
I think we're going to see some pictures of those two Keith.   :D
Offline kmb69
« Reply #10 on: February 22, 2015, 02:37:57 pm »
Right now, both bikes and related hardware are currently in a shipping container while we are changing the layout in the shop and parts room. I will get some pics up when their status changes back to "work in progress". No intention of road racing them as I am old and too brittle. Am more focused right now on a drag bike so I can go play with Billy and the boys.
Offline Jadahonda
« Reply #11 on: March 16, 2015, 07:53:19 pm »
Here is some detail on the CR750 steering damper. It is very much similar with the CL72 damper, but when the CL72 damper has a curved end, this is cylindrical. Also this is zink plated and the CL72 damper is nickled. It should be easy to grind the eye to be like the CR750. The other end seems to be a standard 8mm link.
Now we only need some good photo's of an original rear bracket...
« Last Edit: March 16, 2015, 07:56:25 pm by Jadahonda »
1962 Honda CS92
1968 Honda Z50A
1969 Honda CB750 K0
1970 Honda CB100
1970 Honda CL100
1970 Honda SL100
1971 Honda CB500
1975 Honda GL1000
Offline napoleonb
« Reply #12 on: March 17, 2015, 09:38:50 am »
Great pics,
Would you be so kind as to take a few more pics with the "eye" on the side (looking into the hole)?
Is it a cylindrical straight true hole or does it have a recess on one side? With the risk of over-asking what are the measurements for the eye (outside diameter, inside diameter and thickness)
Offline Jadahonda
« Reply #13 on: March 17, 2015, 12:18:36 pm »
Innside is just as the CL72. The only thing you need is to grind they curved outside flat. From the parts list, it use the same rubber inside as CL72.
1962 Honda CS92
1968 Honda Z50A
1969 Honda CB750 K0
1970 Honda CB100
1970 Honda CL100
1970 Honda SL100
1971 Honda CB500
1975 Honda GL1000
