Author Topic: reaer disc brakes on cb550  (Read 1683 times)
Wis
« on: October 10, 2006, 04:25:22 PM »
i was wondering if any of the 550's had rear discs(my 74 is drum)...also anyone have info on wider rear tires?...can you just fit a different size rim and lose the spacers?
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
Re: reaer disc brakes on cb550
« Reply #1 on: October 10, 2006, 04:38:09 PM »
Rear discs on SOHC4 550's: Nope, all drum.
There's a couple of wide rear tire threads, do a search or two.  I think the discussions were mainly based on how big a tire you could jam on a stock rim as opposed to a replacement rim.  Of course, tread wear and handling may suffer with an improperly sized tire on a stock rim.  But there are replacements available, I just don't know anything about them.  I know there's a few on here running oversized rears...
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
Offline Jv550
  • '75 CB 550 K
« Reply #2 on: October 10, 2006, 05:00:23 PM »
Seeing as how troublesome the front disc brakes are on my 550, I'm pretty happy having a drum on the rear...
That's like hypnotizing chickens...
Offline ieism
« Reply #3 on: October 11, 2006, 03:34:12 AM »
I don't see the point in a rear-disk either. Unless you get a new hub and are looking to save weight maybe..... The reardrum is pretty good, if you want more stopping power the front should be first on your list.
---cb550---
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
« Reply #4 on: October 11, 2006, 11:29:38 AM »
You could probably get a 750F1 rear hub with disc in there but you would need to work out a mount for the master cylinder and res. Also a break steady arm as it needs to be on the top of the swingarm, then rework the brake pedal mount and reposition the brake light switch. Theres no reason why it can't be done but the setup is a bit fierce on the 750 so would probably just lock up all the time on the lighter bike, perhaps modern rubber would cope better......
In the UK anything over 40 years old only needs insurance and Fuel.
Offline dusterdude
« Reply #5 on: October 11, 2006, 12:46:23 PM »
you wont believe how fast a rear disc will stop you.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
