Author Topic: xl250 running but appearing rich?  (Read 10391 times)
Offline cb550fnewb
Re: xl250 running but appearing rich?
« Reply #25 on: February 21, 2015, 01:40:04 PM »
So I put it back together.  I decided to move the needle position one up (leaner since I live at 5600 ft and will be using up to 10,000 ft.
After resetting the idle screw, I let it idle for 10 to 15 minutes then took a quick ride.  It is cold and windy as a storm front is about to come through.  I took it about 3 miles and tried to keep the RPMs above 4k.  Ran fine and plug is brown so after the snow comes and go I will take it for a longer ride to confirm.
« Reply #26 on: February 22, 2015, 04:28:12 PM »
Think I may have found a/the issue.  The choke spring is very weak and barely returns to no choke, so it may be on just a little.  I popped it off and bent it about 1/4" and it now returns properly. Crossing my fingers will she how it goes tomorrow.
If that is it I feel stupid.
If you were applying the choke when you thought you were removing it, then yeah, you could feel stupid. ;) It happened to my buddy more than once on an XR200. Seems the choke was opposite from the XR500 he normally rode. ;D
Offline cb550fnewb
« Reply #27 on: February 22, 2015, 05:42:32 PM »
I won't know for a week or two the snow is falling here.  Hoping it was that and leaning the main needle one position cured her.
