Author Topic: Internal Handlebar Wiring w/Clip-Ons  (Read 2598 times)
Offline redrider736
« on: February 17, 2015, 05:36:06 PM »
Am I able to run the wiring for the MotoGadget M-Switch through Woodcraft Clip-Ons ??? I don't own any of it yet just trying to figure out my front controls and Elec...
78' CB550k (Not Run'n / Basket Case Project)
77/78 cool 2 member #269
Offline Trad
Re: Internal Handlebar Wiring w/Clip-Ons
« Reply #1 on: February 17, 2015, 06:23:14 PM »
Why couldn't you? You need to drill holes obviously. haha. The bars are alloy so it'll be a breeze.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline redrider736
« Reply #2 on: February 17, 2015, 07:52:43 PM »
I hope it wasn't the stupidest question asked??  :o ... but guess I don't mind asking before committing to a order..
ThX
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #3 on: February 18, 2015, 12:14:19 AM »
Not a stupid question at all. A friend of mine has recently hit a problem with his Suzuki, he bought some Renthals for it and then found he couldn't get all the wiring through because of the smaller inside diameter of the new bars. Might be something worth checking before you commit to buy :)
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline Trad
« Reply #4 on: February 18, 2015, 06:51:33 AM »
It's not a lot of wiring though. He was asking about being able to run the wires from the M-switch through the bars. That's only a few wires at best. Not the hefty bundles that come with the stock controls.  ;)
Offline calj737
  • I refuse...
« Reply #5 on: February 18, 2015, 07:52:42 AM »
Yes you can. The m-switch has 2 24AWG wires per button. In fact, they are designed to be run internally. You might want to fish some extension wire from the end out to the switch, then sheath it and push back internally. A rubber grommet installed in the end with a small hole drilled for the wire bundle to pass thru.
Offline redrider736
« Reply #6 on: February 18, 2015, 01:58:19 PM »
ThX Boyz for the info !
Yes you can. A rubber grommet installed in the end with a small hole drilled for the wire bundle to pass thru.
Calj737, Was going to ask ...... but see you beat me to it .. ThX !
